2009 F350 MPG????????? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 11-27-2010, 12:06 AM
newtoford4x4 newtoford4x4 is offline
newtoford4x4 is starting off with a positive reputation.
Wholly crap, HELP!!! I am ready to by a 2009 F350 Dually 6.4l with a 4.30 axle. What should I expect to get for MPG, no load city/highway? I have looked nearly everwhere and can not find the information. I need help!!
Old 11-27-2010, 02:18 AM
Machinator Machinator is offline
Machinator is starting off with a positive reputation.
Well there are lots of factors, THE ONLY reason I would by a truck with that much gear whould be if I was towing upwards of 30k lbs. My 6.4 3/4 ton pulled a 22k 4 axel for 900 miles across Texas and she did it without a hitch and thats with 3.73's I avg over the whole trip 9 mpg's. That was with 2 400lb motorcyles in the bed as well which all combined is f'n heavy for a 3.73 rear truck but she did it but burned lots of fuel cause the trailer full loaded by itself no **** weighed in at a little over 22k lbs! I would say if you cruise at 60-65 without lead footin it you should be able to get 15 or 16 on the highway mabe.
Old 11-27-2010, 05:18 AM
Brandon D's Avatar
Brandon D Brandon D is offline
Lead Foot User
Brandon D is gaining momentum as a positive member of FTE.Brandon D is gaining momentum as a positive member of FTE.
I'm no expert on the dually but I think you'd be VERY lucky to get 15 unloaded, especially with that gearing. I'm sure others with similar trucks will chime in but I would say you can expect 12-14 unloaded, as for towing it would depend on what you are towing but expect to see 7-10. I know that's a wide range but that seems to be the general #'s that most guys post. And of course you are buying a 9000lb dually so I'm sure you aren't expecting 25MPG. My advice is to buy the truck if you need it and are towing heavy loads and if not then you might want to consider a SRW with taller gears. Good Luck
Old 11-27-2010, 06:27 AM
gwcon's Avatar
gwcon gwcon is offline
gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.
I have to be VERY light on the pedal and empty I am barely able to SQUEEZE 13 to 14 mpg out of my 2008 F350 CC DRW with the 4.30. If you hotrod or go above 70 on the highway you will get 11 mpg. City driving kills the mpgs because these trucks are so heavy.
The good news is that when you are towing heavy the 6.4's are only about 1 to 1.5 mpg off of the 6.0's mpg. I pull around 17K to 18K on a regular basis with the truck mentioned above and get 8 to 9 mpg.
I love my truck but great fuel mileage is a pipe dream.
Old 11-27-2010, 07:10 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I think Sdetweil has your same setup as well. I think he sees around 14 on the hwy, 11-12 in the city.
Truthfully these are not city trucks. Too much city driving and you will wish for something smaller.
Last edited by senix; 11-27-2010 at 07:33 AM. Reason: Fixed the spelling on your handle..sorry Sam
Old 11-27-2010, 07:29 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
i have an 08 2wd DRW with 4.11s and get 9 towing 7000lbs at 70mph, 12.5 locally, mostly highway speeds and 14.5 on the highway unloaded at 70mph.
Sam
Old 11-27-2010, 08:40 AM
Guys, thanks a lot! The quick input has helped me make my decision, I should have registered sooner, great forum.
Old 11-27-2010, 09:36 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
What did you get?
Please tell us it's not a Dodge!!!
Old 11-27-2010, 10:18 AM
I am putting an offer on the 2009 F350 DRW, hope to get it!
Old 11-27-2010, 10:29 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
"no load city/highway"
why would you buy a diesel dually work truck with 4:30's if your just going to drive it around empty anyway?
anyway,id plan on a good average of 10mpg at best with the 6.4l setup like this.
(don't be fooled by "highway peaks" unless that's where your drive all the time.)
if your looking for a truck to drive around like a car,i would skip the dually and look for a truck with higher gear ratio as well.you'll save yourself a boat load of cash in fuel if your main speed is 50 mph or higher.
don't forget there is more expense than just fuel with a diesel.
(yes i have plenty of first hand experience with the 6.4l.they are THIRSTY! and the duals eats 1-1.5 mpg's on top of it.-this doesn't hurt a work truck,because it = less trips and more than offsets the mpgs in work hours saved.)
Old 11-27-2010, 10:57 AM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
I have a 2010 F350 4X4 DRW with 3.73s. I am getting around 8-9 pulling a 14k 40ft 5er on the interstates and about 10.5 in the mountains. I have not had the truck out unloaded on the highways/interstates yet. I have around 7k on the truck now. I agree, you should have joined earlier! . These guys helped me long before I pulled the trigger on my F350. I just have to remember, I bought the truck to pull so I don't get that frustrated with the mileage! Good luck.
Old 11-27-2010, 11:58 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Little late I guess but I'll put in my guess that you will see 10-12 on highways. Have a F250 w/ 3.73's that doesn't get much better than that.
Old 11-27-2010, 01:20 PM
fg250's Avatar
fg250 fg250 is offline
fg250 is starting off with a positive reputation.
i get about 14-15 on the highway. 7-10 towing.
Old 11-27-2010, 01:42 PM
RoadJunkie RoadJunkie is offline
RoadJunkie is starting off with a positive reputation.
Whichever truck you get, whatever mileage you get, PLEASE don't write about how the mileage sucks and how disappointed you are, or how you can't wait to DPF/CAT delete... PLEASE! But, enjoy the truck and pull, pull, pull!
Old 11-27-2010, 02:00 PM
tgreening's Avatar
tgreening tgreening is online now
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Quote:
Geez, ya think? I mean what the heck you were only over your rating by about 7000 lbs or so. If you could, keep me posted on your towing schedule and whereabouts, I'd kinda like to avoid the area with my family. I don't consider myself a gram weenie, but come on....
(flame suit on I would imagine)....
2009 F250 5.4L MPG increase, what brand? acwgraphics 1999 to 2016 Super Duty 0 11-07-2016 07:47 PM
HELP! with some simple Q's about DFP and EGR.. turbodiesel6.4 1999 to 2016 Super Duty 3 06-10-2016 09:51 AM
Cruise Control F350 2009 6,4 v8 diesel not work flippflopmann 1999 to 2016 Super Duty 1 11-22-2014 07:00 PM
2009 f150 MPG brent1204 2009 - 2014 F150 7 02-14-2014 12:57 PM
F150 and E150 Engines WoeIsMe 2009 - 2014 F150 31 01-12-2014 04:37 PM
Tags
2008, 2009, 2010, 2011, 350, diesel, f350, ford, forum, gallon, heavy, mileage, miles, mpg, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
