Hyd.Flat or Hyd Roller
I know there are as many different opinions as people. But my thought is that the roller cam is the way to go. One big reason in my mind is that today's oils are designed for roller cams. Many have had trouble with flat tappet cams because of several reasons but one being OIL. They have taken the zinc out.
I'm not going to go into a big discussion about it. But I believe if I was rebuilding my 460 in my 86 F250 4x4 I would pay the extra for a roller cam. I think the roller cam is the best for everyday street use. Now if I was to be building a race motor then I might have to use the flat tappet cam to get what I might want.
That is my two cent on this topic. I'm sure you will get many more opinions with differing views.
Craig
Craig
I was also leaning towards keeping my EFI instead of going to a carb when i rebuild and was wanting to know more about the Fast system you mentioned, i wanted to use Edelbrock aluminun heads and a retro fit roller cam and dump the smog stuff. What do i need to do to my trucks computer to get this to work and will the intake manifold bolt up to Edelbock heads. I know nothing about EFI and was looking for a point in the right direction
Comp Cams (they also own FAST) has also been a good one to deal with, whether it was getting goodies for my C6 through TCI (another Comp owned product) or talking duration and timing specs to get 12:1 to be happy on pump gas, to swapping out a cam that had wiped a lobe on another 460 that a friend had, they always had the information to answer your questions and backed their products 100%.
Anyways, the stock EFI intake will not match to the aftermarket heads. Edelbrock has a intake (Victor series) that has the bungs in place that you can machine for putting injectors in. At that point you could use a Holley 950 Commander to control the whole thing. I have also seen some threads somewhere where guys have done modified EEC's to control the whole thing.
As for TBI style injection, one of the reasons I was looking at the FAST vs. the Holley setup is the Holley TBI needs 15psi, so to use the in tank pumps you need to run a regulator to cut the pressure down, also the Wideband O2 sensor is an upgrade, whereas the FAST system is set to take the hi-pressure (45psi) feed to begin with and also comes with the Wideband O2 sensor to begin with.
It seems after all the research i have been doing on EFI that it appears to be a rich mans toy when it comes to the 460, after buying aluminum heads, a roller cam set up, a complete rotating assembly and having the motor rebuilt i could not see paying an extra 3 grand on a EFI system when i could put that money towards building something way cooler than a 93 F-250. I think i will go with a carb set up and all the crappy issues that come with them cause EFI is looking like one big expensive headache
Thats true.... looking at 1700 for the FAST system I want. That being the case, Aero makes a regulator that you can plumb into the existing fuel lines to cut the psi down for a carb, use a throttle cable from a late 80s carbed 460, and take the fuel pump relay, disconnect the ground wire from the ecm and hook it up to a constant ground, the fuel pumps will still have the safety switch working, and will run all the time the key is in the RUN position.
The FAST system has it's own ECM, and all you need to do is plumb it into the existing supply and return lines. It has a ECM controlled ground wire you will need to hook up to the fuel pump relay, and also controls for electronic fans, etc. Bolts right on top of any 4bbl intake, so you can use the aftermarket heads too.
Mine will be going on top of a Weiand Stealth intake.
Heres the link for the .pdf file with the installation instructions
http://www.fuelairspark.com/Instruct...-%20EZ-EFI.pdf
Unless they started up again ? Crane went out of business some time ago. I wouldn't buy a nos one as there would be no warranty & no customer support.
One thing, BBFs tend to not like hyd roller cams (solid roller yes, hyd roller no) I believe it's due to the canted valve and pushrod angles causing the need for to low of spring pressures to keep from collapsing the hyd lifter and thus can't control a roller lifter on a heavy profile lobe above 5000rpm .
Personall solid roller or just stay with a flat tappet, you will be happier and a LOT less money (and probably be able to get a lot more rpm out of it if you want o)
powerstroker02
18
03-03-2011 11:03 AM
CRUNKED77FORD
07-02-2010 06:50 PM
LindenBruce
03-10-2010 08:57 AM
JBradley500
06-29-2008 10:28 PM
Huntersbo
03-23-2006 12:37 AM
