heater blower motor - Page 3 - Ford Truck Enthusiasts Forums
heater blower motor
  #31
Old 11-27-2010, 10:42 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
How do I change my location setting so that it shows?
  #32
Old 11-27-2010, 11:26 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is online now
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
Jordan, i think I found the animal you are searching for, but I doubt that you'll be thrilled with the $120 pricetag. It is part# 03801 on this page:
http://www.vintageford.com/sect_sear...Heater- Motors
Two speed reversible 12 volt. It actually has 5 wires, but I'm sure you could make it work if the motor would physically fit the heater. The label is a little fuzzy in the pic, but i can make out FASCO. I think I've got a FASCO catalog here in my office somewhere. Maybe i can find the OE part number and you can source it somewhere else for less $$$$.
  #33
Old 11-27-2010, 11:30 PM
Joe, how do you find these things?? 120 is a little steep, but at least i know they are making them! but one thing i started to think about tonight is what kind of switch to use? I would like to find one that will fit the original hole, but not be ugly. The original switches are great except they do not get along with 12v due to that resistor
  #34
Old 11-27-2010, 11:40 PM
What can I say? I'm just a resourceful kind of guy! I remembered seeing it last winter when I was digging around trying to find a suitable 12V replacement for the Magic Air heaters. Oddly enough, Sacramento Vintage had that, too. Give me a little bit and I may be able to find that same motor elsewhere for less cheese. You could probably reuse the original switch and route the current for the slower speed through a remote dropping resistor. There are all kinds of them available from the various OEM's. That's the easy part. Motor first, switch later.
  #35
Old 11-28-2010, 12:07 AM
OK, the FASCO part# of the exact motor that SacVin is peddling is 2807-510-146. It looks like that motor fits school bus heaters and is fairly common. The cross reference is Grand Rock part# GR157. Here's a link to their website with all the motor dimensions:
School Bus Heater Motor
Apparently, SacVin has a pretty chunky markup on them. Does about 20 bucks sound a little more reasonable? Have a look here:
Show Product
  #36
Old 11-28-2010, 10:45 AM
now my jaw hurts from it hitting the table!!!! Glad to see that!! that is most certainly in my price range!! ill go out and measure the original case. Also what is the 5th wire for?
  #37
Old 11-28-2010, 12:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
A ground? Some heaters are mounted in a plastic case, no good connection to ground.
  #38
Old 11-28-2010, 12:29 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Quote:
Most of these motors have a dedicated ground wire in light of the possibility that they will be mounted with rubber shock mounts - negating a good through-case ground. In heaters like ours that wire was simply attached to the metal heater case with a sheet metal screw.
If this heater is isolated, the wire could be extended outside the case and have a bullet connector to attach.ground it to the firewall behind the heater.
Crazy, but doable...LOL!
  #39
Old 11-28-2010, 12:39 PM
Well the motors with 4 wires has a wire for a ground so im still left with an extra wire. I guess ill have to buy one and tear it down!!!
  #40
Old 11-28-2010, 01:02 PM
Maybe a 3 speed motor?
  #41
Old 11-28-2010, 01:04 PM
I was thinking that maybe one is for ground, one is for forward one is for reverse and the other two are for faster speeds in each direction?
  #42
Old 11-28-2010, 01:53 PM
If you look at the picture link directly from SacVin's website at the link I listed above it lists what combination of wires will do what. If I remember correctly, the black wire isn't a ground. It's actually used for one of the speeds. I think the difference here is that this motor is actually wound to provide two different speeds in each direction without a resistor at all. I also ran across a single speed reversible 12V motor with three wires when I was searching for that one. It might be electrically closer to what you actually have, but you'd need a resistor for a slower speed like the original setup.
  #43
Old 11-28-2010, 01:57 PM
That is why the stock switch has a resistor in it, but what kind of switch is used for that motor?
  #44
Old 11-28-2010, 02:00 PM
ALBUQ F-1's Avatar
postin' fool
That's a hell of a motor for $20! I'd snap up a couple
  #45
Old 11-28-2010, 02:02 PM
I most likely will buy one experimental but the switch has me real puzzled, but joe will have solution shortly i would imagine.....
Blower motor relay cadunkle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-17-2016 08:56 PM
Help with blower motor. 03F250SD 1999 to 2016 Super Duty 2 04-26-2015 12:42 PM
1983 E250 Club Wagon 6.9L Diesel Blower Motor issues! LeeTribeRide 1968-2013 Full Size Vans 3 11-09-2013 04:10 PM
Remove Blower Motor on 93 F250 help. lippsenator 1987 - 1996 F150 & Larger F-Series Trucks 1 09-18-2010 04:46 PM
blower motor dont work wattsup Electrical Systems/Wiring 9 10-03-2007 05:37 PM
Tags
12, 1949, 1951, blower, cage, car, ducts, ford, heater, make, motor, muscle, reversed, squirrel, test, truck, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
