Anyone fit 35's with leveling kit? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-26-2010, 07:34 AM
Randomsht Randomsht is offline
Randomsht is starting off with a positive reputation.
Time for new tires on my 01 350 CC long bed PSD. I have a 2" leveling kit in the front and I'm currently running 305/70/16 (32.8x12) mud terrains. Is anyone running a 35" tire with the leveling kit? Any rubbing up front? I am looking to go with 325/65/18 (34.6x12.8). The rims are 18x9 should I go with more than 5" of backspacing? Thanks in advance!
Old 11-26-2010, 08:44 AM
RCKYMTN-PSD RCKYMTN-PSD is offline
RCKYMTN-PSD is gaining momentum as a positive member of FTE.
I would say they should clear. I had a 2000 F250 with the heavy duty service suspension on the front which made it sit level and 35s fit nicely with just a little trimming of the plastic inner fender. Im not sure of the offset, I had Weld Typhoons and BFG 315/12.50/16
Old 11-26-2010, 08:51 AM
squatting just a little - stock suspension, 350 should sit slightly higher with the leveling kit
Old 11-26-2010, 11:57 AM
MikeMcCasland's Avatar
MikeMcCasland MikeMcCasland is offline
MikeMcCasland is gaining momentum as a positive member of FTE.
Yes you can fit them.
This is my 04 F250 with stock suspension except for a Zone Leveling Kit.
Old 11-26-2010, 01:40 PM
Jackemupjoe's Avatar
Jackemupjoe Jackemupjoe is offline
Jackemupjoe is starting off with a positive reputation.
[quote=MikeMcCasland;9605003]Yes you can fit them.
Mike what set up did you use from Zone? Also did you need to do anything else track bar relocater? ive been looking for so long and dont know witch to get.
2004 F-150, 35" Tires, What Lift Is Needed? Dboy23 2004 - 2008 F150 2 05-18-2012 01:33 PM
Oversized tires on OE 18" rim ? my996duc1 6.7L Power Stroke Diesel 8 03-28-2012 02:03 PM
New wheels needed what offset and backspace? Firemudder 1999 to 2016 Super Duty 14 02-04-2011 01:34 PM
35's on my stock f350 merc1975 6.0L Power Stroke Diesel 11 06-14-2010 06:50 PM
Biggest Tire For My Stock 18" Wheels? cdrmotorsports 1999 to 2016 Super Duty 6 08-20-2009 07:52 PM
Tags
2010, 315125016, 35, 35s, duty, equal, f150, f250, f350, fit, ford, kit, leveling, mud, super, terrains
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
