Conflicting information on fuel filter location on 86' F350 - Ford Truck Enthusiasts Forums
Old 11-25-2010, 10:49 PM
RabidJade RabidJade is offline
RabidJade is starting off with a positive reputation.
I am planning on installing a new fuel filter as this one is probably from the factory. However, the filter that I got at Autozone doesn't look like anything I can find on my truck and the one at rockauto appears to be the same thing. My truck has the dual tanks with the "hot" tank system where there is an electric pump in each tank switched by the fuel valve on the frame. I did a basic trace and can't find anything that resembles a filter except for the regulator/splitter/return on the top of the engine right before the carburetor.
Any ideas or knowledge on the idea? I'm used to finding them on the frame rail but this doesn't appear to be the norm.
Old 11-25-2010, 11:51 PM
panman65 panman65 is offline
panman65 is starting off with a positive reputation.
did you look at the main fuel line going into the carb? on some its the metal deal that screws into the carb.
Old 11-26-2010, 03:18 AM
Quote:
Yes, already did. The only part that would contain the filter would be the joint that also is the fuel pressure regulator with the return line coming out of it and running back to the tanks. It might be hidden in there but it would be a small filter and I wanted to make sure before taking that apart.
Old 11-26-2010, 04:42 AM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
What's the number on the filter.
I can do a cross check and see if it's the right one.
Some have a inline filter between the pump and the carb, and some screw directly into it.
Old 11-26-2010, 11:44 AM
Old 11-26-2010, 12:18 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
that fuel filter is built into the inlet side of you carburetor !
Old 11-26-2010, 12:28 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
The filter is the fuel inlet on the carb. Unscrew the line, then the piece it screws into.
Old 11-26-2010, 12:36 PM
So the filter is the little brass piece inside the carb inlet? Doesn't seem like much.
Old 11-26-2010, 12:49 PM
82F100SWB's Avatar
Thats it. Not much of a filter at all, but there's also the pickup sock in the tank, some makers(Dodge for one) only use the pickup sock for filtration, nothing else.
Fuel Hose dpoc 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-03-2016 11:16 AM
Replace fuel lines or add filter? annaleigh 1968-2013 Full Size Vans 8 10-25-2015 10:43 PM
89 F250 460 fuel filter capn_r 1987 - 1996 F150 & Larger F-Series Trucks 6 05-17-2011 06:38 PM
2000 Explorer won't start, low fuel pressure mriplaybass Explorer, Sport Trac, Mountaineer & Aviator 5 01-05-2011 07:39 PM
Fuel Pump Woes LastTudor 1987 - 1996 F150 & Larger F-Series Trucks 8 03-26-2009 11:05 AM
Tags
1986, 460, 86, engine, f150, f250, f350, filter, filters, ford, fords, fuel, installation, location, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
