1 ton front leaf springs on a 3/4 ton?
Old 11-25-2010, 12:41 PM
bleedin'blue's Avatar
bleedin'blue
bleedin'blue is offline
I have an '88 F250, 4x4, 351 auto. reg. cab. I found some front leaf springs off an '87 F350 on craigslist. Would these be a direct fit on my truck? I am looking at a plow for my truck anyway, so would this be worth it?
Old 11-25-2010, 12:45 PM
CJM8515's Avatar
CJM8515
CJM8515 is offline
Depends on what F250 you have, if its the over 8500lb GVW it will work. I think the lighter duty F250 uses smaller springs (width wise).
Old 11-25-2010, 01:30 PM
Redneckryder's Avatar
Redneckryder
Redneckryder is offline
my friend did it. leveled his truck out and everything. I dont think his was a heavy duty F250, as it came with a 351.
Old 11-25-2010, 06:00 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
NO NO NO. Stock F350 springs will not work in a F250 unless you have a D60. The 250 springs are made to not only go up and down but also curve with the arch of the TTB suspension.
The F350 springs are designed to ONLY move up and down. If you use F350 spring , in a short time they will stress them selves in to garbage and sag worse than your original f250 springs
Old 11-25-2010, 06:40 PM
CJM8515's Avatar
CJM8515
CJM8515 is offline
I didnt see he said fronts, no they wont work if they are fronts. Rears work fine, Brads right.
Old 11-25-2010, 10:33 PM
cj06's Avatar
cj06
cj06 is offline
The f250 has TTB front with NEGATIVE arched springs and that f350 has a dana 60 straight axle and those springs are positive arched and will not work !!
Old 11-25-2010, 10:46 PM
bleedin'blue
Alright thanks everyone, I questioned it right away because of the solid axle on the 350's and the TTB on my 250. I have no intention of doing a solid axle swap.
Old 11-26-2010, 05:27 AM
broozerthehoundog's Avatar
broozerthehoundog
broozerthehoundog is offline
The F 250 springs are stiffer. They are a 3400lb spring and the F 350 is a 2200 lb spring.
Stick in an add-a-leaf spring and it will support your plow just fine. The ratings sound wrong,but the ttb needs a stiffer spring. If you do a solid axle swap get the f 350 springs
because the 250's will beat you to death. Don't ask how I know!
Jim
Old 11-26-2010, 07:36 AM
wickedklown83's Avatar
wickedklown83
wickedklown83 is offline
not true, my 89 is factory stock with a 351 and it is gvwr 8600#
Old 11-26-2010, 08:45 AM
jrwhitmire's Avatar
jrwhitmire
jrwhitmire is offline
Jim
He's right, the F350 basically pivots between leaf springs, but the 250's TTB pivots from nearer the center of the truck, much shorter & less leverage, requiring a stiffer spring. Some Greek guy figured this leverage thing out a couple thousand years ago, and some Ford engineer blatantly stole his principle.
Old 11-26-2010, 02:35 PM
BearFootCustom's Avatar
BearFootCustom
BearFootCustom is offline
Same here with my 93
Old 11-26-2010, 04:25 PM
cj06's Avatar
cj06
cj06 is offline
my old 87 f250 has a 351 ans is HD 8600 # c6 2x4
Old 11-26-2010, 06:23 PM
broozerthehoundog
re
I think the Greek guy designed the crappy ttb also!
Jim
'99F250
1999 to 2016 Super Duty
13
12-23-2015 04:00 PM
kioolt
10-25-2013 05:12 PM
FordOwnerJoey
06-21-2012 06:18 AM
daningraham
07-06-2011 11:17 AM
TJDave
02-08-2011 04:09 PM
Quick Reply: 1 ton front leaf springs on a 3/4 ton?
