advanceing timeing
Old 11-25-2010, 08:53 AM
gumper 123's Avatar
gumper 123
gumper 123 is offline
advanceing timeing
does any one have thread for proper procedure. I would like to advance timeing on my 94 idi turbo.
Old 11-25-2010, 09:22 AM
mechelement's Avatar
mechelement
mechelement is offline
I've been trying to find a place to time my truck and have been told repeatedly:
With the truck off, unbolt the three IP adjustment bolts. Locate the hash mark on the IP and the hash mark on the block. Supposedly, if they're aligned right now, you can rotate the pump towards the passenger side by the width/thickness of a hash mark at a time and it will advance the timing. Someone in my thread said to rotate it towards the passenger side the width of 2 hash marks. I believe I was told there's a square slot to fit either a 3/8" drive or 1/2" drive breaker bar to assist you with rotating the pump.
I believe those instructions are to bring it into time with new injectors and a fairly fresh IP. I guess if you want to advance it even more, just keep going hash mark width at a time and see what you think. If you advance it too much, won't you sacrifice power?
Old 11-25-2010, 09:25 AM
Country_boy_2007's Avatar
Country_boy_2007
Country_boy_2007 is offline
thats pretty much what i heard to, i would like to bump the timeing up a little, but it runs pretty good right now so i guess ill leave it alone
Old 11-25-2010, 09:41 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
one way to far or the other will hurt performance and fuel economy.
to much advance,and some have claimed to have ruined a set of brand new glow plugs.
i think timing by ear,is good enough to drive it to the diesel shop lol.
you'll have to be more lucky than good to get it within fords recommended specs,so claim the guys with the proper meters.
Old 11-25-2010, 09:42 AM
WarOzz's Avatar
WarOzz
WarOzz is offline
Make sure to scribe a mark were it's set at before you adjust anything! I borrowed a buddies diesel pulse adapter to do mine, took me a few tries even with that to find the sweet spot. The end result is that since I timed it I got more power and I saw a very slight increase in fuel economy. A key indicator that your not timed right is if it doesn't rattle properly when cold. Mine now sounds like a psd when you first fire it up but mellows out as the engine warms up.
Old 11-25-2010, 09:46 AM
Marshall91F250's Avatar
Marshall91F250
Marshall91F250 is offline
This is where you put your wrench to assist in turning the pump. I was told by dealer 2 hash marks to passenger side is the sweet spot. Just loosen the three bolts on the front of the pump.
Old 11-25-2010, 09:48 AM
mechelement
Ahh, a square bit for a wrench! Thanks!
Old 11-25-2010, 11:42 AM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Well i got to playin with mine and just started advancing until something happened, the farther i went the better it runs... i had it maxed out to the pass. side. And that is the only time i ever heard anything of PSD rattle. Maxed out i did wonder if that might have been as far as it wanted to as i did not see the power gain i did with the other advances. Although, it does seem to start a bit easier backed off a little.
Old 11-25-2010, 05:43 PM
hairyboxnoogle
I went out and checked mine, Right now im about 1/16th of an inch advanced (to pass. side) according to the default scribes on the upper left side of the IP. To me, it ran much better and definately had more power/ smoked less advanced more. But im 99% sure that my IP is fubar'd and there is some reason why im needing to advance it so far to find the "sweet spot"
Old 11-25-2010, 06:13 PM
FORDF250HDXLT
as a rule,they require a rebuild/replacement every 100k miles like the fuel injectors.
they are a medium ware item.
you don't want that "power stroke rattle" after warmup.only when the cold advance is on.
be careful,to much advance you can kill your glow plugs.
Old 11-25-2010, 06:38 PM
hairyboxnoogle
Im curious how the advance hurts the GP's? When i had the IP max advanced you could barely hear it rattle any louder whatsoever when the advance is on, when it was off sounded the same as before i touched it. I did notice that when cold and advance on, under load and under 2000 rpms it would almost sound kinda like detonation if you really got on it. My pump and injectors are pretty rough, ive no doubt about that, they have 272,000 on em, and im sure there is something mechanically wrong with the advance inside the pump. Basically when the internal advance is on, the thing is hardly drivable, surging and what not, and its always done this regardless of base timing.... although it is less noticable with the base timing more advanced. One thing i think i noticed was it didnt like to start as well with it more advanced which i though was odd seeing as it ran so much better and cleaner. But that may be due to my charging system issues and partially discharged batteries so who knows.
Old 11-25-2010, 07:23 PM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
I might have to play with mine a little more.... hmm....
Old 11-25-2010, 09:34 PM
catfish101's Avatar
catfish101
catfish101 is offline
Don't get too crazy on advancing the timing. Remember the faster the pump the longer fuel is burning on the pistons. To early and you will not have enough heat to allow combustion but it will have enough heat to hurt things. You can fry a diesel by getting it too advanced. Have seen it allot over the years. Just be careful.
Old 11-25-2010, 09:43 PM
johnboggs21's Avatar
johnboggs21
johnboggs21 is offline
careful how ya say that...some of the knuckleheads on here like to take things out of context LOL
Old 11-26-2010, 07:24 AM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
Yea...... that could end up in a sig... maybe i should change it...
Catfish, IF i move it at all, it will be just a tiny amount. It seems to run fine, so i may not touch it...
Quick Reply: advanceing timeing
