Nobody seems to know what this is!! 50 F-1
It's a replacement hood that was made some time after 1948-50 production. The basic stamping was made off of the 1951-52 die. It was then finished 1948-50 style. I have seen several NOS ones like this over the years. Ford didn't care about show trucks. They were just supplying parts to keep them going. The same goes for the wide back window 1948-50 cabs. They were later replacements assembled with 1951-52 backs, probably because they ran out of 1948-50's.
Chuck
Chuck
So, Chuck, what you are saying is that Ford would provide replacement parts that were initially stamped out of a similar year (after production for the correct year had ended) and then finished it as close to the appropriate year as they could??????
That would really explain ALOT of the conversations we have had about one part not being quite "kosher" on some of the truck pictures folks have posted!
Bob,
The ribs were added to the back of the cabs some time at the very end of the 1948 production year. Obviously done to stiffen the back of the cab.
There were many features like this on 1948's that were phased out by '49.
Julie,
Like I said, to Ford, parts is parts. They couldn't care less about what's "correct", back then, or today. The replacement part just has to make sense. They wouldn't have expected the customer to use 1951 or 1952 hood moldings on their 1948-50, because that would drastically change the look of the truck. But a missing body line would almost go unnoticed, so they went with it.
Chuck
Julie,
Chuck
They didn't make new ones. It's a multi-hit process to form something like a hood. The basic form die has got to be huge. Just the labor savings of changing dies in the press would be enough to warrant this short cut. If they already had the 51-52 die in the press, it made sense to keep stamping parts until they had enough to fill all orders, and enough extras for stock.
Also, they made so many more 1948-50's than 51-52's that it's possible that the 48-50 die was worn out or broken.
The more I look at this, it looks like the "hit" that made that line and raised area was likely a separate process. The basic form die was the same for 48-52. They just skipped a step in the sequence of finishing it as a 48-50. Again, could have been because of broken or worn out tooling, or could have just been to save some labor. It could have even been a lazy employee who took this liberty on his own, and just sent out a batch like this!
Chuck
Chuck
Thanks for taking time to share your insight Chuck. I have seen pictures of hoods like that before but it didn't catch my attention until pointed out in this thread.
It would be interesting to know the serial number, but especially the cowl stampings in order to locate the plant and approx period the truck was built. Ken?
Tim
Tim
Tim
Tim
I accept Chuck's analysis, but out of general curiosity I'd like to know the details.
IF we should find that several trucks produced at about the same time from the same general area around a particular plant have the same hood, then we'd have to re-consider the conclusions we've drawn. I'm just keeping the door open...........
