Monroe Quick Strut Questions - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign In
Register Forgot Password?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
Old 11-24-2010, 12:44 PM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is gaining momentum as a positive member of FTE.
Hello Everyone!
I decided to replace my shocks and struts since I have 90K and plan on keeping the truck forever. I changed the rears and good thing, they were dead! I replaced the front strut assemblies with the quick struts from monroe. They went on ok, but when I lowered the truck down off the lift, I noticed that the front was about 2" higher than it used to sit. I checked the box and it said that it may ride higher than usual until the new springs "settle" Its been a week and its still the same. It rides good and better than before but sometimes when i go over a bump in the road I hear a "kuh-klunk" that wasn't there before. Put the truck back on the lift twice to double check all the fasteners and they are all tight. I hope its not my ball joints stretching to the breaking point! How much longer do they need to "settle?" Has anyone else used these quick struts and experienced anything like this?
Thanks in advance,
Alex
__________________
Alex
2014 F-150 XLT 5.0
1966 Falcon Ranchero 200ci I6 FCA#13787
2011 Escape XLS
Old 11-25-2010, 09:18 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
As soon as they have been driven 4-5000 miles they should be settled. It way even be quicker than that on those Chicago area roads. It takes a little while for the coils to settle in and compress to the proper height. The more compression/rebound cycles the struts are given the sooner they settle.
Old 11-26-2010, 12:35 PM
mercman86's Avatar
I guess I'll just have to aim for the holes in the road now lol! Im leaving to go to South Carolina soon so Ill see how it is on the highway and after all that driving.
Thanks for the response!
__________________
Alex
2014 F-150 XLT 5.0
2011 Escape XLS
Old 11-26-2010, 12:52 PM
jr105 jr105 is offline
jr105 is starting off with a positive reputation.
I haven't tried them on my truck, but I did put a set on a car and they did raise the front end compared to how it was with the old struts. That was because the old worn struts and springs had sagged and were causing the front end to ride low. I compared the car with the new struts to a newer version of the same model with original struts and the new ones were only slightly higher, maybe 1/2" at most. I assume the same would be true with truck struts.
Old 11-28-2010, 01:07 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
I've been leary of the quick struts for our trucks as there are a number of different spring heights that came stock........it may settle a bit.....but there still may be a difference in height.
__________________
Hey Guys.....vote for me please...
http://www.ford-trucks.com/forums/97...round-7-a.html
Old 12-17-2010, 12:26 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
I have new KYB struts on my '04 2wd. I put new Moog springs on mine and had very little height difference. The ride was noticably smoother over the OEM had ever been. If your height was different I was wondering if the upper and/or lower control arms were tightened in a lowered position than it was originally at. This can cause it to set higher also. I measured the position on mine and put them back to the same position as before.
Old 12-17-2010, 12:31 AM
Added note: The Moog springs have more coils than the OEM springs (which look like the Moog Cargo Coils). This may account for the smoother ride of the Moogs.
Old 12-17-2010, 12:43 AM
rockstate45 rockstate45 is offline
rockstate45 is starting off with a positive reputation.
Just as a reminder, whenever you mess with the front suspension - make sure to get an alignment afterward.
Also, you might try flexing the truck out... help settle them springs a little bit quicker.
-rockstate
__________________
2007 Toyota Tundra 5.7, 4x4
http://i163.photobucket.com/albums/t...100_1749-1.jpg
Rhino Liner, Borla Exhaust,
Ranch Hand Grille Guard,
BFG AT KO 285/65/r18
1998 Ford Expedition 5.4, 4x4
http://i163.photobucket.com/albums/t...5/100_0870.jpg
http://i163.photobucket.com/albums/t...h_100_1201.jpg
Old 12-18-2010, 12:01 PM
Sako 75's Avatar
Sako 75 Sako 75 is offline
Sako 75 is starting off with a positive reputation.
I see that this thread is almost a month old. Hope things have settled down for you.
With the geometry change, you certainly need an alignment. One other thing - due to the change in geometry - you might want to inspect your sway bar links. This could be the root cause of your new "klunk". Be sure to check them with the front end loaded and unloaded, as wear to the links may not present itself while on the lift.
__________________
'04 F-150 XLT SCab 4X4 5.4 Auto. Pic, 268,000. Looks and runs like new. Gave it to Son
'06 F-150 Lariat SCab 4X4 5.4 Auto. 111,000. Graveyard. Truck vs Deer/wet pavement/Cedar grove. RIP.
'08 F-150 King Ranch SCrew 4X4 5.4 Auto. 138,000. Looks and runs like new. My Daily Driver.
Old 12-18-2010, 12:14 PM
mercman86's Avatar
Thank you to all who have given advice about my issue. Im sorry I havent been around in a while to report back. Anyway, I found the "klunk" knoise and I'm very upset about it. Also, the truck has not returned to its normal ride height and they've been on there for a month and about 200 miles. While I was under the hood yesterday changing the idler pulleys and the tensioner, I leaned on the truck to reach for somthing and my weight lowered the front of the truck slightly. When I let my weight off the truck, it popped back up making the "klunk." I had my buddy stand on the bumper and bounce it up and down while I looked at the strut towers. The center stud with the nut on it that holds the strut together was moving up and down! Thats whats making the noise. Both sides are like that. I tried to tighten them but they wouldn't budge. Its almost like they forgot a washer or shim when they were assembled. From my experience, the stud is not supposed to move when the strut moves up and down. I will be calling Monroe's tech support people on monday to tell them whats going on. The website said that I have 90 days to decide if im satisfied with their product. So far, Im not. Good thing I saved my old struts, I may just throw them back on before my 1,000 mile drive next week.
Thanks again guys!
__________________
Alex
2014 F-150 XLT 5.0
2011 Escape XLS
Old 12-20-2010, 03:37 PM
mercman86's Avatar
Looks like I've fixed it. After talking to Monroe this morning, their tech told me that I should be able to tighten up the loose shock nut. He also said that there isn't a washer that goes under the nut so it just wasn't torqued correctly. It took a while, especially on the passenger side (not a lot of room to swing a wrench around) and I was able to get them both properly torqued which made the noise go away! Im so glad that it turned out to be a minor thing. I must say that they handled my complaint very well and were eager to assist even if it meant that I was still dis-satisfied and was going to return them.
Thanks again to all for the imput!
__________________
Alex
2014 F-150 XLT 5.0
2011 Escape XLS
Old 12-20-2010, 05:43 PM
Glad you got it!
Got any before and after pics of hte truck?
-rockstate
__________________
Old 06-19-2011, 10:22 PM
JB3 JB3 is offline
JB3 is starting off with a positive reputation.
Thank you for posting this! I just put the quick struts on yesterday evening and spent most of today trying to find the "klunk" noise. After basically going over the entire front end....again....I read your post. Took me about three minutes to fix with an air gun. No more "klunk"! It is a shame that a company who is aware that something such as this happened, didn't do anything about it. Even something as simple as adding a note to each box saying to tighten it. However, they work great now! I also installed Sensatrac load adjusting shocks in the rear. My F150 handles and rides fantastic. Thanks again for the post! BTW, I accessed the nut from the engine compartment with an air gun and extension. This saved a tremendous amount of time. I tried tightening the nut through the wheel well, but the rod just span.
Old 06-20-2011, 06:17 PM
mercman86's Avatar
Quote:
Glad that I was able to help and that you were able to get it right! That is really sad that we had this problem. That means that probably all of them have this problem of being loose. When I called monroe they claimed that they had never had anyone call and complain about those nuts being loose. My struts have been fine and the truck ride height in the front has come down a little bit, it is not as low as it was with the old struts but it now is pretty close. So far so good. Does your steering effort feel a little different? At first, mine was a little tight but then returned to normal.
__________________
Alex
2014 F-150 XLT 5.0
2011 Escape XLS
Old 06-21-2011, 06:04 AM
JB3 JB3 is offline
Quote:
The steering may be just slightly tight, but nothing very noticable. It definitely sits taller in the front. I bought the truck used and found it had a front-end leveling kit installed, which is simply a block on top of the strut. Maybe this is why I didn't notice much difference in the steering.
Did Monroe tell you how to torque the nut? Just curious, because I had to tighten it all the way in order to eliminate the noise.
Similar Threads
Installed new Rear Hatch Lift Struts G550_Capt Excursion - King of SUVs 15 02-23-2015 10:11 AM
2005 Escape Strut/Shock Replacement donsabi Escape & Escape Hybrid 20 12-30-2012 03:41 PM
Shocks, Struts replacement jbtecnico1 Escape & Escape Hybrid 10 10-10-2012 04:47 PM
front strut change out rickfar Escape & Escape Hybrid 4 05-28-2011 08:28 PM
Best Shocks and Struts??????????????? fetterjohn Explorer, Sport Trac, Mountaineer & Aviator 16 01-30-2003 01:05 AM
Tags
05, 150, 2004, change, escape, f150, ford, good, heights, monroe, quick, riding, settle, strut, struts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
