94 f250 blend doors - Ford Truck Enthusiasts Forums
94 f250 blend doors
Old 11-24-2010, 04:57 AM
Psykoemaniac Psykoemaniac is offline
Psykoemaniac is starting off with a positive reputation.
94 f250 blend doors
Okay, so my heat isn't working but the heater core tubes get hot so I don't think it's that. I've read a lot of posts (none specifically for my case, all for f150's.. is it the same?) but i'm a little confused on the best way to get to the blend doors on my truck. I read a post about being able to reach the blend doors after removing the heater core? Also, taking the glove box out, I have a box in the way of the ?plenum? which I'm lead to believe (from other posts) is the abs control module, which i unscrewed both screws. Next I read about removing 10 screws to access the heater core from inside the cab. This is the tricky part. I've read about both needing to do it from inside and outside the cab and if this pertains to me since that was from a f150 post.
Also, it's cable controlled since most posts talked about being actuator controlled?
Any feedback is appreciated! Thanks!
1994 f250 w/ 460
Old 11-24-2010, 10:23 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Yes the F150 and the F250 are the same.
You can only get at it from inside the cab.
All blend doors are cable controlled.
Yes you have to take out the 10 screws to see it form inside along with the glove box. This allows you to remove items that may have fallen down from the vents and blocking its operation.
Note that the cable control is on top and if that is the problem you can get at it with out removing the 10 screws.
Blend door control:
The ten screws:
Old 11-24-2010, 06:42 PM
Awesome thanks for all the info and the pictures!
Edit
Do I need to pull the dash off?
Old 11-24-2010, 08:38 PM
Ok done! I will post pics of my blend door controller it is a little different just incase anyone needs to reference it. Also for my truck, there were only 7 screws to remove. Also had to unclip wires from a few places but it is removable without taking apart the dash! Hope this helps someone out in the future!
Old 11-24-2010, 09:05 PM
imabaka's Avatar
imabaka imabaka is offline
imabaka is starting off with a positive reputation.
I've seen it break at the controller **** before.
Old 11-25-2010, 04:49 AM
kyjoe9 kyjoe9 is offline
kyjoe9 is starting off with a positive reputation.
I learned alot from this topic. I am also having the same problem and am looking forward to get my heater back on.
Old 11-25-2010, 05:17 AM
Oh by the way I didn't replace my blend door I just took a book of matches and a pen out and voilą! Heat! Glad you found it helpful, I looked through over 100 threads before pieceing together enough info to figure it out for my model.
Old 11-25-2010, 05:45 AM
Alright, this is the abs controller, sitting infront of everything, disconnected:
This is with the abs controller out of the way but you can still see the abs controller cable (the black and grey bunch) and the other cable that i removed (the white colored pieces) The two copper colored pieces are where the abs module was screwed into. You can also see the cable for the blend door in the black sleeve making a "U" from bottom left going to the right then ending at the to top left and the controller being the white pieces top left:
This is what my cable looked like, a little different than subfords:
Hope this helps and feel free to ask questions!
Old 11-25-2010, 06:30 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Thats what my cable looks like. Just ease the end of the cable off of the little shaft that its sitting on. Then the white cylinder part has a clip on the back.
Old 11-25-2010, 07:11 AM
Good to know, I didn't need to take the white piece on the right off, just unhooked the cable from the piece on the left with my fingers (went back on just as easy). The piece on the right came off (attached) when i took the heater core cover off.
Old 11-25-2010, 10:48 AM
Thats right it does. For some reason I had to take mine off once before, but that might have been when I replaced the cable.
Old 05-08-2013, 11:55 AM
clean concepts clean concepts is offline
clean concepts is starting off with a positive reputation.
aaaaha! this thread made my day! heater stuck on hot since my heater core replacement a few months ago. didnt realize until it got to 90+ here last weekend and no cold air in the cab. my ******* didnt clip the cable bracket back in and therefor no movement of the actuator door... cold and comfortable now. thank you!
Old 11-08-2016, 09:11 PM
BigredInstalls BigredInstalls is offline
BigredInstalls is starting off with a positive reputation.
So i've begun searching google for a new controller anticipating the cable has streached... i can't find a cable driven controller. Any hints out there?
Old 12-15-2016, 06:35 PM
c_land c_land is offline
c_land is starting off with a positive reputation.
Hi everyone. My first post here I'm having similar issues. Can anyone indicate whcih way the blend door should be positioned for hot air?
Old 12-16-2016, 09:19 AM
subford's Avatar
To the left.
99 Expedition replace blend door - cut hole method rexpedition99 Expedition & Navigator 4 12-02-2015 02:14 PM
Heater/blend door trouble shooting Tommy Mack 1997 - 2003 F150 8 10-29-2013 08:02 AM
2000 Expy Heater Core and Blend Door brimis Expedition & Navigator 1 09-24-2013 02:09 PM
New blend door actuator not working papa t Cooling, Heating, Ventilation & A/C 2 11-19-2011 06:38 PM
94 E150 blend door ?s sc93f Cooling, Heating, Ventilation & A/C 1 02-13-2004 10:54 PM
Tags
1994, 1996, 1997, 2008, 250, 94, ac, blend, blender, door, doors, f150, f250, ford, pictures, taurus, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
