96 stroke fuel leak.
That's how I did mine. The plunger kinda clicks in the fuel pump and that holds it. I think the instructions say if the motor is turned over just right the lobe on the cam would be up and that would push the plunger up. but I didn't know how to make that happen other then just luck. If the lobe is up it will push up on the pump when you unbolt it, but you will still probably have to wiggle it to get it loose and push down on the new one a little.
EC.
Here's one link to the 'famous' Sam Miller writeup on changing the fuel pump:
https://www.ford-trucks.com/forums/8...ml#post7450178
(If necessary, just copy it into the brower's address bar.)
I went thru this several months ago (both the fuel bowl and then the pump). On my non-cali '96, you can get the banjo bolt free with just a regular craftsman 1 1/4" combo wrench. Takes a little while, just keep at it. The box end will break it free and tighten it. And you can leave the turbo alone.
My hands are 'small' so it wasn't too bad taking the bolt out the last couple threads by hand. I'd suggest a rag under the bolt before you pull it to catch the inside sealing washer, in case it falls free.
As far as the tappet in the pump goes, mine stayed in just fine. The key is to lift the pump straight up. The 'trouble spot' is that last 1/8" or so when you can tilt the pump. If that happens, the tappet can drag on the side of the bore and get pulled out of the pump as you lift it. I found you can keep the pump 'staight up' by twisting it slightly. If it gets 'tilted', it won't twist and you need to get it squared up before continuing.
Last item - I had a bunch of "wet dirt" under the pump. The lifter bore doesn't have any boss around it. Whe you go to clean it, the dirt can easily get pushed into the bore. I made a plug with a foot long dowel, wrapped with electric tape to fit snuggly in the hole. with 20/20 hindsight, I'd measure the new pump's tappet boss and make up a 'plug' so when the old pump comes off, the plug can go right in without having to 'adjust it' to get it to 'fit'.
#28
#29
Nobody will probably recommend this, but I put on a face sheild and stuck my pressure washer down I in the valley and blasted most of the crap out of there. I didn't get carried away though because I didn't want to hit any electrical stuff. Just the valley and not when the motor is hot. I took a chance and didn't destroy anything. It also helped me find my leak because the I could dry it off really well. There was still a small amount of crud around the bore, much easier to clean up though and less chance of getting crud in the motor. Good luck!
#30
