LIKE THE OLD SAYING GOES "IF AIN'T BROKE, DON'T FIX IT". MY '87 RANGER 2.9 V6 HAS 200K MILES ON THE ORIGINAL WATER PUMP. SO IF IT'S NOT LEAKING OR HAS A BEARING NOISE I'D LEAVE IT ALONE.
I have the same 32V Intech engine.
I didn't even think the pump was bad because it was not overheating. I wasn't getting as much heat as I was used to...took off the pump and the impeller was sheared right off. (It's a very cheaply made pump, using thin tin as an impeller.)
