1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Truck shakes violently when I hit a bump at 50+mph
Old 11-23-2010, 09:55 PM
guidry23's Avatar
guidry23
guidry23 is offline
Cool Truck shakes violently when I hit a bump at 50+mph
I have a 07 f250 6.0 with a 10.5 inch bds lift. Tires are 40x15.5 22inch rims Toyo open country mt. I bought the lift and installed it, and when I would get over 30 the truck shook so bad I had to stomp the brakes, so I installed a dual steering stabilizer, and then I had no problem for a couple of months.
Then all of a sudden when I hit a bump at 50+ it shakes so bad I have to slow down to about 25 before it stops. I Checked the steering stabilizer, and all components are tight.
I was wondering what else can cause the death wobble
Any information would be a great help thanks
Old 11-24-2010, 10:38 AM
guidry23's Avatar
guidry23
guidry23 is offline
Any thoughts
Old 11-24-2010, 10:45 AM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
What have you done in regards to the track bar?
Did you have any caster/camber shims installed?
Did you have a "Proffesional" alignment after installing the lift?
What is the condition of the ball joints/tie rods etc..
Old 11-24-2010, 12:26 PM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
10.5" is a ton of lift. I'd be calling BDS. I doubt any alignment shops will be very interested in helping you on this.
Old 11-24-2010, 12:46 PM
JohnF350Outlaw's Avatar
JohnF350Outlaw
JohnF350Outlaw is offline
I had the same type of thing happen but not where I had to slow to 25 mph. Anyhow, my issue ended up being a centerlink end. Replaced and realigned for $200 at a Ford dealer about 20k miles ago and all has been well.
BTW-My truck is stock except for 2.5" Front Levelers with Factory 20" Rims
Old 11-24-2010, 01:48 PM
redford's Avatar
redford
redford is online now
Received 1,562 Likes on 910 Posts
TSB
07-10-10
STEERING WHEEL OSCILLATION
Publication Date: May 10, 2007
FORD:
2005-2007 F-Super Duty
This article supersedes TSB 07-5-7 to update the Parts.
ISSUE:
Some 2005-2007 F-Super Duty vehicles may exhibit steering wheel oscillation (back and forth motion), immediately following front or rear wheel impacts (i.e. pavement joints, frost heaves, rough roads, etc.). Steering wheel motion is typically in the range of ± 5 degrees, and typically dampens out in fewer than five oscillations. This condition occurs mostly on F-250/F-350 4X4 vehicles, and is more evident on trucks equipped with a gas engine.
ACTION:
Refer to the following Service Procedure to minimize the steering wheel oscillations on impacts, however, there may be some remaining minor oscillation which would be considered normal.
SERVICE PROCEDURE SUMMARY
Set tire pressure and road test vehicle to evaluate vehicle before proceeding with further repairs. If issue is resolved, do not proceed with the rest of this TSB.
If concern still exists, install a new steering damper (frame-mounted bracket and steering damper assembly on F-250/F-350 4X4 applications only). For F-250/F-350 4X2 and all F-450/F-550 applications, inspect damper for leaks and replace if necessary, torque steering and suspension fasteners per Workshop Manual (WSM).
If concern still exists, check front alignment and reduce front caster.
Replace redundant control steering wheel (if equipped and vehicle built prior to 10/8/2004).
VEHICLE INSPECTION - TIRE PRESSURE
Set tire pressures as indicated on the vehicle label (located on driver's door label).
NOTE: SETTING TIRE PRESSURE TO DOOR SPECIFICATION IS ONE OF THE SINGLE MOST IMPORTANT MEASURES IN RESOLVING THIS ISSUE. LOWERING TIRE PRESSURE WILL MAKE THIS ISSUE WORSE.
ROAD TEST
Ask customer what type of road surface and speed generates the steering wheel oscillation.
Road test vehicle on similar road surface and speed, to gain a feel for the customer's issue.
If no issues are identified during the road test, do not proceed with the rest of this TSB.
STEERING DAMPER INSPECTION/REPLACEMENT AND STEERING/SUSPENSION FASTENER TORQUE CHECK
F-250/F-350 4X4 Applications:
Remove existing steering damper and frame attachment bracket.
Replace steering damper and frame mounting bracket with steering damper and frame bracket.
Attach steering damper to frame bracket and torque bolt to 76 lb-ft (103 N-m).
Assemble bracket and shock assembly to the frame with attachment bolt retainer pointing to rear of vehicle. Torque frame bracket nuts to 59 lb-ft (80 N-m).
Attach other end of shock to the steering drag link and torque to 66 lb-ft (90 N-m).
Install damper bolt cap to assure a friendly surface for the battery cable in case of casual contact.
NOTE: CHECK SURROUNDING ENVIRONMENT TO THE FRAME BRACKET AND DAMPER ASSEMBLY TO ENSURE THAT BATTERY CABLES ARE NOT CONTACTING BRACKET/BOLTS/DAMPER. ALSO, VERIFY THAT TRANSMISSION OIL COOLER LINES HAVE CLEARANCE TO THE DAMPER DUST SHIELD.
F-250/F-350 4X2 And All F-450/F-550 Applications:
Wipe down and inspect the steering damper. Turn the steering wheel from lock to lock several times to cycle the steering damper and inspect for leaks.
If leaks are present, install a new steering damper.
Steering/Suspension Fastener Torque Check (4X2 And 4X4)
Check torques on the following steering and suspension fasteners and adjust to specification as required (see following Table).
Torque Specification
Description Lb-ft Nm
Damper nuts (F-250/F-350 4X2) 59 80
Damper-to-bracket (F-250/ F-350 4X4) 76 103
Damper-to-drag link 66 90
Drag link-to-pitman arm nut 129 175
Inner tie-rod end nuts 85 115
Outer tie-rod end nuts 85 115
Track bar bracket-to-frame nuts and bolts 129 175
Track bar-to-track bar bracket bolt 406 550
Track bar-to-axle nut 185 250
Radius arm-to-axle bolts 222 300
Radius arm-to-bracket nut 222 300
NOTE: ADJUSTING TORQUE ON STEERING AND SUSPENSION FASTENERS IS VERY IMPORTANT IN RESOLVING THIS ISSUE. FASTENERS THAT ARE IMPROPERLY TORQUED WILL MAKE THIS ISSUE WORSE.
FRONT WHEEL ALIGNMENT AND REDUCE FRONT CASTER
NOTE: OSCILLATION ISSUES RESOLVED BY WHEEL ALIGNMENT ARE WARRANTED FOR 12/12 ONLY, REGARDLESS OF OTHER STEPS PERFORMED.
Measure wheel alignment. Verify that front caster, camber, and total toe are within specification. Adjust as required. Refer to the WSM, Section 204-00 for complete alignment specifications.
REDUCE FRONT CASTER
Note the current front caster.
Use alignment adjustment bushings to reduce front caster by 0.5 to 0.75 degrees. The caster setting may be at the lower end of the specification as long as the vehicle drives smoothly. Do not put caster setting below the lower specification limit. Use alignment adjustment bushings.
F-250/350 4X4:
5C3Z-3B440-CCC (0.5 degree bushing)
5C3Z-3B440-DDD (0.75 degree bushing)
5C3Z-3B440-EEE (1.0 degree bushing)
F-450/550 4X4 and 4X2:
5C3Z-3B440-HHH (0.5 degree bushing)
5C3Z-3B440-JJJ (0.75 degree bushing)
5C3Z-3B440-KKK (1.0 degree bushing)
F-250/350 4X2:
5C3Z-3B440-C (0.5 degree busing)
5C3Z-3B440-D (0.75 degree bushing)
5C3Z-3B440-E (1.0 degree bushing)
For All 4X4 and for F-450/550 4X2:
Rotate the alignment adjustment bushing so that the bushing hole is in the 45 degree forward and inboard position. (See Figure 1)
Figure 1 - Article 07-10-10
This should lower the caster, while keeping the camber within the specification range. If the camber is not in the specification range than rotate the alignment adjustment bushing as needed.
The final caster and camber settings must be within the specification limits.
Maintain the current front camber, cross-camber and cross-caster settings as close as you possibly can.
Adding weight behind the rear axle lowers the rear of the vehicle, which decreases the frame angle, which in effect increases caster.
For All F-250/350 4X2:
Observe the camber position of the alignment bushing that is currently in the truck and attempt to maintain that position while moving the caster position forward in the truck.
NOTE: CASTER SETTING IS VERY IMPORTANT IN RESOLVING THIS ISSUE. INCREASING THE CASTER SETTING WILL MAKE THIS ISSUE WORSE.
REPLACEMENT OF REDUNDANT CONTROL STEERING WHEEL - Vehicles Built Prior To 10/8/2004 Only
NOTE: THE REPLACEMENT STEERING WHEEL WILL CONTAIN THE REDUNDANT CONTROLS.
Remove driver air bag assembly. Refer to WSM, Section 211-04 for complete instructions.
Remove the steering wheel.
Install new steering wheel.
Reinstall driver air bag assembly.
Re-set clear vision as required.
NOTE: FOR ADDITIONAL INFORMATION, PLEASE REFER TO SECTION 211-04 OF THE WSM FOR COMPLETE REMOVAL AND INSTALLATION PROCEDURES FOR THE STEERING COLUMN.
PART NUMBER PART NAME
5C7Z-3600-ABA Redundant Control Steering Wheel Asy (King Ranch Tan/Peb)
5C7Z-3600-CBA Redundant Control Steering Wheel Asy (Charcoal Black)
5C3Z-3B440-C F-250/350 4X2 (0.5 degree bushing)
5C3Z-3B440-D F-250/350 4X2 (0.75 degree bushing)
5C3Z-3B440-E F-250/350 4X2 (1.0 degree bushing)
5C3Z-3B440-CCC F-250/350 4X4 (0.5 degree bushing)
5C3Z-3B440-DDD F-250/350 4X4 (0.75 degree bushing)
5C3Z-3B440-EEE F-250/350 4X4 (1.0 degree bushing)
5C3Z-3B440-HHH F-450/550 4X4 and 4X2 (0.5 degree bushing)
5C3Z-3B440-JJJ F-450/550 4X4 and 4X2 (0.75 degree bushing)
5C3Z-3B440-KKK F-450/550 4x4 and 4x2 (1.0 degree bushing)
W520117-S441 Nut - Hex - RH Thread
W706196-S439 Bolt
7C3Z-3E652-C Bracket
5C3Z-3E651-B Steering Damper (F-250/F-350 4X2)
8C3Z-3E651-C Steering Damper (F-250/F-350 4X4)
5C3Z-3E651-D Steering Damper (F-450/F-550)
W711570-S300 Bolt Cap
NOTE: LABOR OPERATIONS IN THIS TSB CAN BE CLAIMED TOGETHER.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
071010A 2005-2007 F-Super Duty: Check Tire Pressure, Road Test To Verify Repair, Concern Resolved, Return To Customer (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 0.4 Hr.
071010B 2005-2007 F-Super Duty: Check Tire Pressure, Road Test To Verify Repair, Concern Not Resolved, Check Steering Damper Replace If Necessary, Verify Proper Torque On Steering Components, Road Test If Concern Is Resolved Return To Customer (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 1.4 Hrs.
071010C 2005-2007 F-Super Duty 250/350 4X2 DUAL REAR WHEEL: Check And Adjust Front Wheel Alignment, This Labor Operation Can Be Claimed With Operation B Only (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 1.9 Hrs.
071010C 2005-2007 F-Super Duty 250/350 4X2 SINGLE REAR WHEEL: Check And Adjust Front Wheel Alignment, This Labor Operation Can Be Claimed With Operation B Only (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 1.5 Hrs.
071010C 2005-2007 F-Super Duty 250/350 4X4 SINGLE REAR WHEEL: Check And Adjust Front Wheel Alignment, This Labor Operation Can Be Claimed With Operation B Only (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 1.8 Hrs.
071010C 2005-2007 F-Super Duty 250/350 4X4 DUAL REAR WHEEL: Check And Adjust Front Wheel Alignment, This Labor Operation Can Be Claimed With Operation B Only (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 2.1 Hrs.
071010C 2005-2007 F-Super Duty F450/550 4X2/4X4 DUAL REAR WHEEL: Check And Adjust Front Wheel Alignment, This Labor Operation Can Be Claimed With Operation B Only (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 2.3 Hrs.
071010D 2005-2007 F-Super Duty With Redundant Steering Control Built Prior To 10-8-2004: Replace Steering Wheel, Includes Time To Depower And Repower The Supplemental Restraints System Can Be Claimed With Operation A Or B (Do Not Use With 1007D, 3001A, 3001A1, 3001A6, 3600A) 0.7 Hr
DEALER CODING
BASIC PART NO. CONDITION CODE
(Operation A) NPF 82
(Operation B) 3E651 42
(Operation C) FRONT W6
(Operation D) 3600 42
redford's Avatar
redford
Sorry - double post.
Old 11-24-2010, 01:57 PM
429poweredf350's Avatar
429poweredf350
429poweredf350 is offline
Had same issue
The track bar and the drag link MUST be parallel to each other. If not it creates bump steer. Also, make sure there is "0" play in all the front end joints......tie rod ends, drag link, etc. I replaced the drag link, the track bar ball joint (crappy setup) and had it aligned at a shop that works with lifted trucks. Put 10K miles on since and wobble is all gone. The track bar design is the root of this problem. Ford acknowledges the side effects but doesn't see it as a problem. What a load of crap. I still don't have the warm and fuzzy about the ball joint. There are some after market solutions in the $700-$1K range. Too much for me. I'm working on fabbing my own solution.
Old 11-24-2010, 06:27 PM
guidry23's Avatar
guidry23
guidry23 is offline
I had it aligned after it was lifted, there is no problems with the lift kit. Thanks for the replies
Old 11-24-2010, 06:32 PM
guidry23's Avatar
guidry23
guidry23 is offline
It does not happen all the time, if the steering wheel is straight or turned to the right it never occurs, it happens when it's turned to the left, just for some more info
Old 11-24-2010, 07:43 PM
Arlene's Avatar
Arlene
Arlene is offline
Just passing through...
Had the same thing happen after a tire rotation and 'alignment'. Found that one of the tires (that moved from back to the front) had a small bad spot in it. Unrotated the tires... problem solved.
May or may not be your problem, but thought I'd mention, in case you hadn't looked at that possibility.
Old 11-24-2010, 08:15 PM
few2many's Avatar
few2many
few2many is offline
Hmm, straight, right or left.
Crank the wheel to the left and look at the front end. Tanke note or even a pic of the linkages.
Crank the wheel to the right. If the track bar and draglink run out of place with each other, could be that.
Is this 4x4?
Can you get us a front on pic of the suspension.
Old 11-24-2010, 08:17 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
redford i thought you were ranting there for a minuite LOL.
Ok, at first the issue is at 50+ MPH and is more excessive when turning left/right?
I don't recall anyone commenting of the fact that there was anything "wrong" with the lift per say.
Jerry is on the right track.
With a combination of a 10.5" lift and 40" tires i would be suprised if it didn't vibrate at some point. when lifting that high, steering geometry becomes very difficult to control in all situations. As you didn't "confirm" some of the items i mentioned i can only assume worse case scenarios. The alignment on a truck lifted that high has to be done by a proffessional experienced in lifted trucks. Was that the case? As jerry mentioned and IMO you have excessive bump steer as well. "All" front end items as well as tire and wheel combo's need to be carefully analized to eliminate them as a problem.
I also bet it won't take long for a vibrating 40" tire to create it's own issues with the front end. A proper alignment on your truck should have taken close to an hour or more depending on the shop.
Give us some detailed info on the truck so we can help diagnose better. Mileage, components and type actually changed or replaced, recent maintenance etc..
Old 11-24-2010, 08:27 PM
few2many's Avatar
few2many
few2many is offline
I'd have to agree, wheel hop/oscilation with bad bump steer. Things are probably lined up better when turning left.
There it is, Zoolander, you cant turn left!(or was it right, havent seen the movie in a long time)
Old 01-06-2017, 07:04 AM
Richard Shifflett's Avatar
Richard Shifflett
Richard Shifflett is offline
I just had new wheel bearing put in on passinger side both upper and lower control brushing new shocks on front end and front end alignment now when I hit a bump at about 50 it's shaking like the hole front end is going to fly out CAN ANYONE HELP ME
kev987
2017+ Super Duty
51
02-01-2022 07:47 PM
windyhill
11-12-2021 08:05 PM
SuperDutyPrime
12-28-2017 11:28 AM
TC-Countryboy
09-20-2017 09:52 PM
acwatkins
03-29-2017 08:13 AM
Quick Reply: Truck shakes violently when I hit a bump at 50+mph
