AE Help - KOER test procedure
Need the procedure for doing the KOER test. I don't understand what and when I am supposed to do the steps regarding turning the wheel , brakes etc.
Any help would be great. Does the KOER test, test the cylinder contribution? If not how do you do that test and procedures if required.
Thanks really appreciate some help!
I dont remeber about the KOER test and the sterring and brake thing. But the cylinder contribution test can only be run with the upgraded connector. Would have cost me about $100 more to exchange mine. I called them with the number on my connector and they told me in a few seconds Icould not run it.
I recently upgraded to V9.0, but the screen was the same on the V8.X versions. There is a tab in the interface called "Test OnBoard System" where I run this from. The screen prompts when to turn the wheel, touch the brake, etc. Sorry, I can't figure out how to attach a screenshot.
I called Autoenginuity. The guy said don't worry about prompts. Once you hear the RPMs change do the following:
Press brake pedal
Crank wheel all the way to either right or left
Press tow/haul button
Said doesnt matter which order.
Ill try in the next couple days and see if it works. Let me know how it goes for you.
Press brake pedal
sandymane
17
07-01-2017 12:00 PM
texasyakfisher71
08-03-2010 01:30 PM
