05 6.0 heater blowing cold air
Old 11-23-2010, 08:19 PM
cooter05's Avatar
cooter05
cooter05 is offline
My 05 is blowing cold air out of heater after it is warmed up. At an idle it blows hot but after you drive a few minutes it blows cold. Under accel it will also cool right off. Today driving home in the bitter cold, cruising on hiway, blowing ice cold I pulled over to check heater hoses. Ice Cold, yet temp gauge normal, degas normal no venting. HG's changed with studs, EGR cooler checked, new cooler, new injectors. Ongoing now for a couple years. No summer heating issues. Very Confused. Help. Could it be thermostat?
Old 11-23-2010, 09:06 PM
Nitrous's Avatar
Nitrous
Nitrous is offline
Maybe your heater core is bad.
Old 11-23-2010, 09:12 PM
flamebuster's Avatar
flamebuster
flamebuster is offline
Gauges have a lot of range in temp. without moving..This happened a couple yrs. ago in one of our ambulances. The thermostat was stuck open. Replaced and all was well...
Old 11-23-2010, 09:24 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
A ODBII reader (ie: scangauge2, insight, etc.) can give you the actual
temp. The dash gauge is a very crude device 100 or 180 reads pretty
much the same thing.
If you could read the coolant temp you'd find a bad thermostat
because the temp would be below 190 once warmed up.
Old 11-23-2010, 10:22 PM
cooter05's Avatar
cooter05
cooter05 is offline
Thanks guys, I'm gonna try the t-stat on the weekend.
Old 11-23-2010, 10:27 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
MoyockPowerstroke is offline
My vote is stuck open t-stat or blend-door faulty (I'm not sure if the blend-door is vacuum driven or mechanical). How does your top rad hose feel (hot/cool....solid/colapsed)?
Old 11-24-2010, 08:54 AM
69cj's Avatar
69cj
69cj is offline
Also check the vacum line on the heater control valve. They are known to get knocked off or leak vacum. Gray vacum line near the add oil spout.
Old 11-24-2010, 10:27 AM
Jim83's Avatar
Jim83
Jim83 is offline
That happend to me. turns out i was low on antifreeze. check it you might just be low.
Old 11-25-2010, 08:56 PM
cooter05's Avatar
cooter05
cooter05 is offline
Smile
Changed the t-stat tonite and now hot as he**. Thanks for all the help.
Old 11-25-2010, 10:47 PM
flamebuster
Great to hear.. Especially with winter coming on strong this year....
Old 02-14-2014, 09:10 AM
Dinger08's Avatar
Dinger08
Dinger08 is offline
Hey guys I'm having issue with cold air just replaced t stat didn't change nothing..when I turn heater off of change to ac that heater control valves stays open what can I do to fix it...thanks
Old 02-14-2014, 10:54 AM
Fal-308-Win's Avatar
Fal-308-Win
Fal-308-Win is offline
Could be a vacuum leak. Check heater control on heater hose above passenger side valve cover. See if you can move the lever by hand. Watch the control while an assistant turns on the heater to see if it moves and check the gray vacuum line with a vacuum gauge.if your not getting hot air the control is probably staying closed,I'd wire it open until the weather warms up and tackle it then.
Old 02-26-2014, 09:10 PM
Fishak's Avatar
Fishak
Fishak is offline
Mine is blowing cold air only at idle. Any throttle setting above idle produces the proper heat. Vacuum issue?
Old 02-26-2014, 10:31 PM
miner999r's Avatar
miner999r
miner999r is offline
Check vacuum pump, as well???
Old 02-26-2014, 11:13 PM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Yours doesnt sound like a vacuum problem to me. Check coolant level, possible reasons for yours is water pump impeller is broke, thermostat, blocked heater core, head gaskets.
pjohn192
6.4L Power Stroke Diesel
01-20-2017 05:39 PM
Tulsamulerider
01-10-2017 10:28 PM
scrobbie
1997 - 2003 F150
12-10-2016 02:37 PM
Tobnpr
1997-2006 Expedition & Navigator
07-28-2016 09:09 PM
killerklown
09-21-2012 07:42 AM
Quick Reply: 05 6.0 heater blowing cold air
