05 6.0 heater blowing cold air - Ford Truck Enthusiasts Forums
Old 11-23-2010, 09:19 PM
cooter05 cooter05 is offline
cooter05 is starting off with a positive reputation.
My 05 is blowing cold air out of heater after it is warmed up. At an idle it blows hot but after you drive a few minutes it blows cold. Under accel it will also cool right off. Today driving home in the bitter cold, cruising on hiway, blowing ice cold I pulled over to check heater hoses. Ice Cold, yet temp gauge normal, degas normal no venting. HG's changed with studs, EGR cooler checked, new cooler, new injectors. Ongoing now for a couple years. No summer heating issues. Very Confused. Help. Could it be thermostat?
Old 11-23-2010, 10:06 PM
Nitrous's Avatar
Nitrous Nitrous is offline
Nitrous is gaining momentum as a positive member of FTE.
Quote:
Maybe your heater core is bad.
Old 11-23-2010, 10:12 PM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
Gauges have a lot of range in temp. without moving..This happened a couple yrs. ago in one of our ambulances. The thermostat was stuck open. Replaced and all was well...
Old 11-23-2010, 10:24 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
A ODBII reader (ie: scangauge2, insight, etc.) can give you the actual
temp. The dash gauge is a very crude device 100 or 180 reads pretty
much the same thing.
If you could read the coolant temp you'd find a bad thermostat
because the temp would be below 190 once warmed up.
Old 11-23-2010, 11:22 PM
Thanks guys, I'm gonna try the t-stat on the weekend.
Old 11-23-2010, 11:27 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.
My vote is stuck open t-stat or blend-door faulty (I'm not sure if the blend-door is vacuum driven or mechanical). How does your top rad hose feel (hot/cool....solid/colapsed)?
Old 11-24-2010, 09:54 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Also check the vacum line on the heater control valve. They are known to get knocked off or leak vacum. Gray vacum line near the add oil spout.
Old 11-24-2010, 11:27 AM
Jim83's Avatar
Jim83 Jim83 is offline
Jim83 is starting off with a positive reputation.
That happend to me. turns out i was low on antifreeze. check it you might just be low.
Old 11-25-2010, 09:56 PM
Smile
Changed the t-stat tonite and now hot as he**. Thanks for all the help.
Old 11-25-2010, 11:47 PM
Great to hear.. Especially with winter coming on strong this year....
Old 02-14-2014, 10:10 AM
Dinger08 Dinger08 is offline
Dinger08 is starting off with a positive reputation.
Hey guys I'm having issue with cold air just replaced t stat didn't change nothing..when I turn heater off of change to ac that heater control valves stays open what can I do to fix it...thanks
Old 02-14-2014, 11:54 AM
Fal-308-Win's Avatar
Fal-308-Win Fal-308-Win is offline
Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.
Could be a vacuum leak. Check heater control on heater hose above passenger side valve cover. See if you can move the lever by hand. Watch the control while an assistant turns on the heater to see if it moves and check the gray vacuum line with a vacuum gauge.if your not getting hot air the control is probably staying closed,I'd wire it open until the weather warms up and tackle it then.
Old 02-26-2014, 10:10 PM
Fishak Fishak is offline
Fishak is starting off with a positive reputation.
Mine is blowing cold air only at idle. Any throttle setting above idle produces the proper heat. Vacuum issue?
Old 02-26-2014, 11:31 PM
miner999r's Avatar
miner999r miner999r is offline
miner999r is gaining momentum as a positive member of FTE.miner999r is gaining momentum as a positive member of FTE.
Check vacuum pump, as well???
Old 02-27-2014, 12:13 AM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Quote:
Yours doesnt sound like a vacuum problem to me. Check coolant level, possible reasons for yours is water pump impeller is broke, thermostat, blocked heater core, head gaskets.
99 Expedition 5.4 Overheating - Blowing Cold Air wobblyBit Expedition & Navigator 6 10-30-2014 01:23 PM
2010 Lariat-Blowing cold air on driver's side doocrue 2009 - 2014 F150 10 09-23-2012 08:23 PM
Heater blows cold air bblaylock 1999 - 2003 7.3L Power Stroke Diesel 6 02-03-2010 11:32 PM
Heater blowing cold air arieldg Expedition & Navigator 5 10-14-2009 02:07 PM
Heater Blows cold air blackexpedition Expedition & Navigator 2 12-20-2008 08:18 PM
Tags
2004, 2005, 60, air, blowing, cold, diesel, excursion, f150, f350, ford, heater, idle, powerstoke, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
