Maximum weight in bed.
How you load it can matter. 3000 pounds of gravel loaded as far forward as possible isn't going to be a problem. Even a 3000 pound pallet of something, forward, is going to be OK.
I have to mention though, I've seen guys with 3000 pound 8-10 foot slide in campers in a short box, with the front wheels barely touching the ground. That is bad.
As long as you use some common sense and be careful, you should be fine.
Well mission accomplished. Hauled my 3000 lb load 204 miles, to its destination. The a** end was really sagging though. I put the weight as far forward as I could. There was about 1/2" between the axle and the bump stops. I think I will upgrade the suspension before I do something like this again.
What are some good suspension upgrades that you can do?
Riderite helpers kick azz.Firestone Industrial Products Co. ~RIDE-RITE™ Air Helper Spring
A world of difference from stock. I did have to modify the spacers on the mounts to give the bags more space because the plates were too close together and the bags would max out too easy.
I am 100% happy that I have them on my truck!!!!!
JamesRogers7
02-14-2016 03:56 PM
