Gas Tank Fill-Up slow - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-27-2000, 07:18 PM
pmmorgan pmmorgan is offline
pmmorgan is starting off with a positive reputation.
I have a '99 EB with the towing package and the 30 gal tank. Regardless of how much gas I need to add for a fillup, the last five (5) gallons takes forever to get into the tank as it keeps cutting off the gas pump. I realize this not earth shattering, but it is frustrating and if someone has an answer, I would appreciate it.
Old 03-01-2000, 06:47 AM
jason jason is offline
jason is starting off with a positive reputation.
I experienced this problem with my '90 EB Bronco w/ 32 gal. tank. The problem may be related to a kinked air vent hose or it may have come loose. My 2000 Expy shuts off before full but closer to the last 1-2gals. These larger tanks need a good size air vent to allow fumes to prevent the pump from shutting off from feedback. Some people have no problems, others do. Ford usually isn't much help unless you lead them to a solution. Do you experience some pumps being worse than others?
Old 03-01-2000, 07:18 PM
frog frog is offline
frog is starting off with a positive reputation.
Of the 15 or so Fords I have owned in the last 25 years, all were slow fill. Something to do with the design of the tank. Ford states in the owners manual to go to shut off at least 3 times to insure a full tank. And many times it is the pump putting out to much pressure and not giving the tank time to vent. Besides, set the shut off to slow fill, and have plenty of time to clean your windshield and check under the hood!!!!
Old 03-07-2000, 03:49 PM
Alexng Alexng is offline
Alexng is starting off with a positive reputation.
On the Explorer newsgroup, someone posted this issue with the Explorer gas tanks as well. Someone posted a do it yourself solution:
fill tank with using the nozzle upside down method? It works!
Here's the thread from that newgroup:
<a href="http://www.4x4central.com/ubb/Forum1/HTML/001575.html">http://www.4x4central.com/ubb/Forum1/HTML/001575.html</a>
Old 03-09-2000, 09:49 PM
James James is offline
James is starting off with a positive reputation.
fuel spill during fill-up tuffnuff45 1999 to 2016 Super Duty 3 05-20-2015 09:28 AM
The drawback of my 36 gallon tank .... flixden 2009 - 2014 F150 34 03-06-2012 11:24 AM
What size fuel tank? Mohave 1999 to 2016 Super Duty 7 07-13-2009 10:09 AM
Accuracy of info centre message on 06 Escape Ltd scp6 Escape & Escape Hybrid 6 05-18-2006 08:03 AM
gas fill-up question who1975 1997-2006 Expedition & Navigator 14 11-07-2003 10:38 AM
Tags
02, 1972, 99, explorer, f250, fill, fills, ford, gas, lincoln, rear, slow, slowly, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
