Why add 2 cycle oil to diesel fuel? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-23-2010, 06:14 PM
rackhound rackhound is offline
rackhound is starting off with a positive reputation.
I noticed in a thred a couple of days ago discussing the type of 2 cycle oil to add when filling up with diesel. Why is this done? How many of you guys add 2cycle?
Old 11-23-2010, 06:15 PM
Skip1970's Avatar
Skip1970 Skip1970 is online now
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
to lube up the fuel side of things.
Old 11-23-2010, 07:51 PM
97-psd's Avatar
97-psd 97-psd is offline
97-psd is gaining momentum as a positive member of FTE.
I run it almost every time I fill up, maybe it is my imagnation but I can tell a difference in how the injectors sound if I forget to add it
Old 11-23-2010, 08:24 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
I am very interested in doing this and remember reading about it a little. How much do you guys add and what kind are you using? Injection, tcw-3, standard 2 cycle oil, etc?
Old 11-23-2010, 09:14 PM
mcallister mcallister is offline
mcallister is starting off with a positive reputation.
Yes, I always use Lubro Moly Super Diesel Additive every fill up, great stuff and found at Napa......but what is this 2-cycle add?? Somebody please explain!!
Old 11-23-2010, 09:21 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Quote:
I use injection and/or TCW-3 which ever is cheaper.I have been getting injection oil for $6.50 a gallon
Old 11-23-2010, 09:23 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
I add 2-cycle and DK everytime I fill up as well.
Old 11-23-2010, 09:26 PM
Jager Jager is offline
Jager is starting off with a positive reputation.
How much do you add per full tank?
Old 11-23-2010, 09:30 PM
riverrat41's Avatar
Quote:
Well let me admit that I am bad about not measuring exactly.
2-3oz of DK w/16-20oz of 2-cycle.
Old 11-23-2010, 09:33 PM
^I would like to know as well. I have a 45 gallon tank. Anyone run tranny fluid? I have ran hydraulic fluid in there as well. Runs like a firecracker when combined with Lubro Moly!!
Old 11-23-2010, 09:35 PM
rbaker6336's Avatar
I use about a 1/3 DK to oil,then about 16oz to a fill up would equal bout 3/4 oz of the mix per gal
Old 11-23-2010, 09:41 PM
riverrat41's Avatar
Quote:
I ran tranny fluid in mine for years but then I learned here about the 2-cycle.Switched to it because it is a burning oil.
Old 11-23-2010, 09:46 PM
Ah, I have never ran it. So, roughly one quart per fill up....I always fill it up when it's a 1/2 tank. Cool, I'll give it a try.
Old 11-23-2010, 11:38 PM
Is using an additive like Stanadyne enough or should 2 cycle be added also?
Old 11-23-2010, 11:52 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Can I just add regular 2 cycle oil like what you would put in a weed eater or any type of lawn equip or does it have to be a special type of 2 cycle oil? I have alot of quarts just sitting around would like to do something with them.
Standard Tune-Up jdavis36 2004 - 2008 F150 3 09-07-2016 11:51 PM
anybody add 2 cycle to fuel waumpuscat 6.0L Power Stroke Diesel 23 01-23-2016 01:29 PM
2 cycle in a 2006 DomsF250 6.0L Power Stroke Diesel 18 08-12-2014 01:33 PM
2 cycle oil???? kdokey 1999 - 2003 7.3L Power Stroke Diesel 21 01-21-2011 10:40 AM
Adding 2 cycle oil to diesel fuel? tractorfan 1999 - 2003 7.3L Power Stroke Diesel 19 10-03-2008 03:32 AM
Tags
2cycle, 62, 64, 73, adding, cycle, diesel, ford, fuel, oil, power, powerstroke, psd, put, stroke, strokes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
