anti theft module
Old 11-23-2010, 04:58 PM
dt95350's Avatar
dt95350
dt95350 is offline
anti theft module
any help would be appreciated. my alarm went off by itself,would not respond to key to deactivate.had to unplug fuse. now with fuse back in ,the throttle does not work check engine light comes on while throttle is depressed. truck starts and idles but no throttle.could anti theft malfunction cause no throttle?
Old 11-23-2010, 06:29 PM
Hussler's Avatar
Hussler
Hussler is offline
What truck do you have?
What anti theft device .. after market or stock?
More information please.
And welcome to FTE.
Old 11-23-2010, 06:36 PM
dt95350's Avatar
dt95350
dt95350 is offline
thank you for the welcome i have a 95 f350 xlt it has fatory anti theft. 7.3 powerstroke was automatic changed to 5 speed
Old 11-23-2010, 06:45 PM
dt95350's Avatar
dt95350
dt95350 is offline
a little history;had a fire that started in bed it spread to cab alot of smoke and heat damage when i went to pick up truck, the alarm was set off when i put key in to start i removed fuses and drove it on trailer. i have since replaced EVERYTHING INSIDE TRUCK. i replaced door windows, and was trying to set off alarm . all seemed to work fine. the nxt day alarm went off by itself. had to remove fuse to shut off . after replacing fuse alarm is quiet but no throttle. mindboggling.
Old 11-23-2010, 07:01 PM
Hussler's Avatar
Hussler
Hussler is offline
It sure sounds like the IVS (idle validation switch) might be stuck closed. Look down at the accelerator pedal and you will see a red button (switch) that comes up when you press on the accelerator. If you press on the go pedal and that red button does not come back up then you will get the symptoms you are seeing. If that's the case then just work (push) on the red (IVS) button to try and make it work.
Old 11-23-2010, 07:24 PM
dt95350's Avatar
dt95350
dt95350 is offline
thanks going to try it now
Old 11-23-2010, 07:40 PM
dt95350's Avatar
dt95350
dt95350 is offline
i looked at ivs working fine. i then looked at fuse panel remember i told you i changed EVERYTHING inside cab including fuse panel cover it came from 94 150 gas truck. it says fuse # 3 not used . on a whim i put fuse in and presto throttle works. thank you so much for your help. in a round about way you solved my problem for me thank you . my truck has been sitting since 10-09 . thank you again for your help
Old 11-23-2010, 08:08 PM
Hussler's Avatar
Hussler
Hussler is offline
Your welcome and glad you got it up and running ...
Old 12-10-2012, 12:43 PM
louise57's Avatar
louise57
louise57 is offline
no orignal key
i just bought a 2000 ford ranger truck.it didn't come with the chip key,so now i can't lock my doors as the anti-theft is on.is there a way to remove the anti-theft.
Old 12-10-2012, 12:50 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
Try to get another key. You will like it that way.
beef tits
04-04-2017 11:20 PM
moorbl
01-27-2016 03:51 PM
dieselaholic
10-11-2010 06:14 AM
01x7.3
03-19-2007 06:37 PM
jbass
Electrical Systems/Wiring
04-04-2004 10:50 AM
Quick Reply: anti theft module
