Bed mounting Bolts - Ford Truck Enthusiasts Forums
Bed mounting Bolts
Old 11-23-2010, 03:32 PM
swordman's Avatar
swordman swordman is offline
swordman is starting off with a positive reputation.
Question Bed mounting Bolts
I don't come to this site all that often but I've run into a problem in putting my 1978 F150 4X4 back together. I'm in need of the 8 bed mounting Bolts and can't seem to find anyplace that has them can anyone help. All info is welcome and thank you.
Old 11-24-2010, 04:49 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
I have had the same problem. I have found them through Ford but they are expensive. LMC and Dennis Carpenter have them for something like $25.00 for the set of eight.
Old 11-24-2010, 08:39 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
They are just a carriage bolt, you can get them at most any hardware store.
Old 11-24-2010, 09:50 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
Quote:
Everything I have seen has too small of a square on the head.
Old 11-24-2010, 01:52 PM
78longbed's Avatar
78longbed 78longbed is offline
78longbed is starting off with a positive reputation.
Try Mikes Truck salvage. I got a set of used bolts and nuts from him awhile back, very reasonable. I believe he was, or still is a sponsor of this site. I can't seem the find the # for you.
Old 11-24-2010, 03:31 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
I dont know why everyone insists on using those stupid carrage bolts. Just get some regular bolts, the length you need then you can actually remove the bolts with 2 wrenches. Instead of the carrage bolts spinning in the bed.
Old 11-24-2010, 03:51 PM
PA74F250's Avatar
PA74F250 PA74F250 is offline
PA74F250 is starting off with a positive reputation.
I'm with Diesel Brad the hex head work just fine.
Old 11-24-2010, 05:45 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Just need 2 people to remove them.
Old 11-24-2010, 06:32 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
.... or a loooooooooooong breaker bar wedged against the bed!
Old 11-24-2010, 06:34 PM
yeah but those get annoying as you are getting towards the end of getting the nut off when they keep slipping and you have to climb back out from under the truck to set it back up again and then hope it doesn't slip/move...
Old 11-24-2010, 06:41 PM
nothercrash's Avatar
nothercrash nothercrash is offline
nothercrash is starting off with a positive reputation.
Well the round shallow heads of the carriage bolts do alot for letting you slide stuff in and out easier, so depending on what you use your bed for... But ya, face any resistance on that nut and the bolt will just spin out the sheet metal. Anyway though, hardware store. I've found that one way to tell a really great hardware store is how much weird stuff for your truck you can find there.
Old 11-24-2010, 07:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Unless they've changed in the last year or so all LMC's bolts are, are regular carriage bolts. Dennis Carpenters are the correct bolt but the nuts in his set aren't. He uses regular hex nuts and lock washers while the correct nuts are crimped lock nuts.
Here is a picture of the Dennis Carpenter bolt, the lower left in the picture.
Old 11-24-2010, 08:02 PM
Its not like you are going to remove the bed yourself, gonna need at least one other person for that
Old 11-24-2010, 08:45 PM
When I'm removing bed bolts I am not always removing the bed. Even then - you do NOT need 2 people to get a bed on or off. I've taken quite a few beds off and on by myself! Putting this '87 on my supercab a few weeks ago was the last one I did...
Just a cherry picker, me and 10 minutes or so!
Old 11-24-2010, 09:19 PM
[QUOTE=ChaseTruck754;9599311]When I'm removing bed bolts I am not always removing the bed. Even then - you do NOT need 2 people to get a bed on or off. I've taken quite a few beds off and on by myself! Putting this '87 on my supercab a few weeks ago was the last one I did...
you are a better man than I
Short bed floor replacement/patch brown78 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-24-2016 01:20 PM
Bed mounting bolts 1997 F350??? Ziob 1987 - 1996 F150 & Larger F-Series Trucks 11 12-03-2015 07:51 AM
Bouncing Bed and Bed bolts Flyboys3 2004 - 2008 F150 11 09-21-2010 12:35 PM
76 f250 bed replacement 82ford302 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-13-2010 04:40 PM
Bed or Cab loose off road brf2 1999 to 2016 Super Duty 9 04-20-2009 04:26 PM
Tags
2003, 78, bed, beds, bolts, box, f150, f350, ford, mounting, pick, pickup, ranger, remove, spin, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
