ideas?
Old 11-23-2010, 02:28 PM
bighalt56's Avatar
bighalt56
bighalt56 is offline
ideas?
Any one have ideas on how to move the brake pedal farther away from the gas pedal on a 56 f100 automatic?
Old 11-23-2010, 02:51 PM
Alcaeus's Avatar
Alcaeus
Alcaeus is offline
I may be totally off but why not just heat it and bend it.
Old 11-23-2010, 03:10 PM
Old F1's Avatar
Old F1
Old F1 is offline
I’m sorry, please forgive me………................…….sit in the passengers seat!
Why do you want to do this, feet get hung up in the pedals, put a offset brake pedal pad on?
Old 11-23-2010, 03:52 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
This may be thinking too far outside the box, but was any consideration given to the fact it may be easier to move the gas pedal farther away from the brake pedal, instead, if indeed there truly is a problem here?
Old 11-23-2010, 03:53 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,108 Likes on 2,642 Posts
Is your pedal a hanging one or does it still go through the floor? I have a hanging pedal and will have to cut the tab the pedal bolts too off and flip it to the opposite side and reweld it, if that's not enough I'll give a little bend to the arm.
Old 11-23-2010, 04:15 PM
bighalt56's Avatar
bighalt56
Yes feet do get in the way my cuz is a paraplegic. We could just cut the pedals off out of the way but his wife sometimes drives him around.
Old 11-23-2010, 06:11 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
There you go making sense again!
It's going to be kind of hard to gain more space between the gas pedal and steering column no matter where yo utry and move the brake pedal.
I'm with Wayne, I'd move the gas pedal out and inch or so. Much easier to do.
Old 11-29-2010, 09:24 PM
Stephen67's Avatar
Stephen67
Stephen67 is offline
Are you doing it for how the pedals are in relation to each other when you use them or do you need to adjust the spacing on the underside?
Being a blacksmith I'd just work the arm till it was where I wanted. Or you could maybe make a custom bracket that holds on the pedal (not the arm but the circle pad) and have it move over a couple inches. Just an idea, would need to be done solid so it didn't break.
Old 11-29-2010, 10:24 PM
cmoritz's Avatar
cmoritz
cmoritz is offline
I have worked on several vehicles over the years that had equipment installed for handicapped persons, one such system had a palm operated brake pedal.
Having an Automatic trans is a decided advantage (I also know a person missing one leg who drives a 4wd-4 speed manual trans..)
If one was to mount a lever to the upper part of the steering column,..then an adjustable rod from one end of that lever to the brake pedal and the other to a palm control you would be in business...
Takes some getting used to I must admit..the 2nd driver will need to "re-learn " how to operate the vehicle I would guess. I just drove them in and out of the shop..didn't trust my "un-trained" self on the highway..where there's a will, there's a way!
Old 11-29-2010, 10:28 PM
cmoritz's Avatar
cmoritz
cmoritz is offline
Also, check in my gallery and look in the first group of Pic's for the gas pedal relocation.
It may give you some ideas.
Old 11-30-2010, 01:33 PM
old_dan's Avatar
old_dan
old_dan is offline
You might try contacting Engineered Components. They sell offset hanging brake pedal assemblies.
