Sway Bar Downlink Issue
Good Evening,
I am having difficulty with my front sway bar downlinks, they keep coming loose. I have recently replaced them for the same reason with some O'Reilly Auto Parts house brands, they seemed alright when compared to the Motorcraft replacements, they even had grease fittings which was unusual for some of the others I have seen. I have torqued them down, I have tried red locktite, the only thing I have not tried is to weld them. It is only the lower nut which keeps coming loose.
thanks,
Jeff
thanks,
Jeff
I recently swapped my worn stockers for some Dormans. The driver side routinely lost torque and would work off until finger loose. I bumped the torque up from 85 to 100, it seems to have fixed the issue so far. I would have preferred to double nut them, however I didn't have any spare hardware at the time.
Richwon4
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
05-06-2020 08:44 PM
