blinkers stay on - Ford Truck Enthusiasts Forums
blinkers stay on
Old 11-23-2010, 01:34 PM
newBstroker's Avatar
newBstroker newBstroker is offline
newBstroker is starting off with a positive reputation.
blinkers stay on
when i turn them on the stay on in the cab and the bulbs. where is the flasher element on out trucks.
Old 11-23-2010, 02:05 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
By your left knee.
Remove the cover and you will see it and the in cab fuses.
Old 11-23-2010, 03:58 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Mine do that every now and then. Just pull the flasher out and tap it on the steering wheel a few times and put it back in. They should start flashing again. When you pull the fuse cover off, the flasher is in the lower right hand slot.
Old 07-24-2014, 04:06 PM
Shmoozer2 Shmoozer2 is offline
Shmoozer2 is starting off with a positive reputation.
Tap blinker module to fix.
Quote:
You fixed my blinker constant "on" problem. Removed it, tapped it a few times, replaced and works like new. Thank you.
Dash lights stay on cdmm151 2009 - 2014 F150 8 01-17-2017 09:47 PM
rabs self test not working justcruzin125 1987 - 1996 F150 & Larger F-Series Trucks 17 03-01-2016 06:44 PM
Trucks won't stay cranked but a few seconds then dies! Weeks7524 6.0L Power Stroke Diesel 3 12-18-2015 11:28 AM
Can you adjust how long headlights stay on after truck turns off? foxbodyford Excursion - King of SUVs 27 11-13-2015 03:39 PM
Dash Camera - where to hook up power? 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 2 09-02-2015 09:21 AM
Tags
03, 1977, blinkers, explorer, f150, ford, stay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
