Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 11-23-2010, 06:00 AM
Blade79's Avatar
Blade79 Blade79 is offline
1989 Ford F-250
Blade79 is gaining momentum as a positive member of FTE.Blade79 is gaining momentum as a positive member of FTE.
Coolant Leaking
Hey guys. Got a little issue. I started the truck last night to let it run since I havent driven it in a while and I noticed it was running a little rough. Was thinking it was cold and just needed to run a bit but I poped the hood anyway and looked around. Found a puddle of coolant behind the water pump by the distributor. Didn't see any of the hoses leaking so I'm thinking it must me the gasket on the water pump?? It looks like the previous owner had replaced it and had used that gasket maker stuff instead of buying a regular gasket. Could this be the issue or could it be something else I am missing?
__________________
Rick Kerfoot
89-F250 Project truck
  #2 (permalink)
Old 11-23-2010, 10:34 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
If it isn't the gasket, look to see if it's leaking out the "weep hole" on the bottom of the pump. Either way, it's gotta come off......but that in itself shouldn't make it run rough.....
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #3 (permalink)
Old 11-23-2010, 01:20 PM
dustybumpers's Avatar
dustybumpers dustybumpers is online now
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
look up by the throttle body, on the left. there is a small,3/8 hose that comes from a metal line.it comes in from the top, and goes back out of the bottom. is actually 2 lines to make up a heater to the throttle body. check that it is not rotten, and broke from all the work you did lately. this hose is not available now, so just cut it and use fuel line.
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Quote:
Originally Posted by 67nukeford View Post
Charlie, don't make me come there and kill you...
"If more sane people were armed, the crazy people would get off fewer shots."
  #4 (permalink)
Old 11-23-2010, 05:24 PM
jr32560's Avatar
jr32560 jr32560 is offline
Maryland chapter LDR
Garage is empty, add now
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
either like the others said or the intake manifold
__________________
Junior Hardy-
1990 F150 302
1995 E250 4.9
member of the Boy you ain't Right club #4
President of the crap shooters club
Tags
2008, 64, coolant, diesel, distributer, f150, ford, leaking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
