cheap lifts?
#61
lol! I'm being serious when I say I've always wanted to built a truck dedicated to tractors. A 4x2 with a lift, big tires in the back, small in the front, leveled out and painted John Deere green. With a super low gear and some kind of I-6 engine.
And calling the 300 a tractor engine is pretty accurate. Never saw a stock tractor get in a hurry, have you? haha.
I love the 302 but I'd never want to pair it with 35's. Or a 300 for that matter. Lot of tire to turn.
#62
#65
#66
Anything over 3" is illegal. And there is a reason for it. Body lifts are unsafe. Period. But go ahead, after all your life is worth your truck looking and handling like crap.
#68
And sure, anything can brake stand. The bigger the tire the harder it is for those brakes to hold back anyway.
#69
What happens when you stuff a set of 38" Swampers under a 3.50 geared F150 with a stock 302 and drive into a mudpit??
What happens when you hit the same pit with a stock 460 powered F150, 3.50 gears, with 38" Swampers?
Same pit with a much better cam and carb'd 460 in a 78 Bronco with 38's and 3.50's?
Just sayin....
#70
Dropping the transfer case into "low range" doesn't count
Just sayin....
Just sayin....
#73
#74
You might want to start a new thread, as not to hijack this one. But my guess off of the limited info you provided would be axle u-joints.
#75
Body lifts aren't that bad. My F250 will be running a 2" when the Cummins goes in and now that I think about it, and walked outside at 11:00 at night and looked my Chevy has a 3" and I have experienced absolutely no ill effects on the Chevy, nor do I expect any on the F-250. The right way to do a body lift on one of these trucks is to buyqa kit, no hockey pucks, no welding tube to the body mounts (although I did that on a Tracker) just break down and spend the 150-200 on a kit that will include your bumper brackets, steering extension, and shifter extension for your automatic, if you have a stick get used to the idea that your **** will be a couple inches lower and get a taller one so it's comfy again. Otherwise, a 4" suspension for one of these trucks will cost you about 600 plus a pitman arm, and clear your 35s at the lift manufacturers recomended offset and backspace.
