Front End Rebuild Kit - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-23-2010, 02:02 AM
dmartinez21 dmartinez21 is offline
dmartinez21 is starting off with a positive reputation.
A few months ago I was on here looking at write ups for ball joints, knuckle seals, etc. There was a company website posted that sold the ball joints, knuckle seals, oil seals, o-ring's, etc., in one big kit.
What I was wondering is if anybody knew the company that did that? Or possibly even another company that offers the same package or close to?
I know the ball joints were MOOG and the seals were OEM.
-Thanks
Old 11-23-2010, 03:31 AM
MikeMcCasland's Avatar
MikeMcCasland MikeMcCasland is offline
MikeMcCasland is gaining momentum as a positive member of FTE.
Dmartinez21,
It's PowerStrokeShop.com. I bought the exact same kit. It was of outstanding quality.
Your Premiere Source for Ford Truck Parts and Accessories
The best writeup out there:
2004 F250 Ball Joint Replacement
Old 11-23-2010, 03:32 AM
Sorry I linked you to the kit I got with the ball joints, seals, and wheel bearings. Here is the one you're looking for:
Old 11-29-2010, 06:38 PM
Thanks Alot! That's exactly what I was looking for. If I knew how to give a positive vote or something I would.
Old 04-15-2011, 10:04 PM
CanadianCowboy89 CanadianCowboy89 is offline
CanadianCowboy89 is starting off with a positive reputation.
What happened to PowerStrokeShop? The website is down and there is a note that says they are not accepting any more phone or internet orders after March 12, 2011. Is there a good alternative source for F-350 Front End rebuild kits?
Old 04-16-2011, 08:56 AM
Monster-4's Avatar
Monster-4 Monster-4 is online now
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
You can order a complete kit from Ed.
www.partsguyed.com
Old 12-04-2014, 10:25 AM
fakirone's Avatar
fakirone fakirone is offline
fakirone is starting off with a positive reputation.
This site seems to be down and I would assume that the company no longer exists. Does anyone know where I can get a kit to rebuild the front end on my '93 F350? Everything that can wear is worn and needs to be replaced. I would certainly rather try to order it all together rather than piece by piece.
Thanks in advance.
Ball Joint Replacement Parts Platinum08 1999 to 2016 Super Duty 1 08-11-2016 06:14 PM
knuckle seal part number 78fordman 6.0L Power Stroke Diesel 4 01-13-2014 09:48 AM
1971 F250 front axle seals 1971fordbluehealer 1967 - 1972 F-100 & Larger F-Series Trucks 1 03-11-2011 05:52 PM
Loose dust seal on axle shaft/knuckle Wide Open Throttle 1999 - 2003 7.3L Power Stroke Diesel 13 12-27-2009 08:24 PM
need seals for closed knuckle 44 78fordranger 1973 - 1979 F-100 & Larger F-Series Trucks 12 02-07-2008 07:54 AM
Tags
1966, 1997, 1999, 2000, 54l, end, excursion, f250, ford, front, kit, rebuild, superduty, suspension, top, tractor, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
