Glow shift color change
Hey guys, so I've been doing some searching but not comming up with the answers I need. Ive installed glowshift 7 color changing gauges. I can operate the color selection, and the auto change/fade option. However when I set a desired color it wont stay on that color after I turn the truck off? I assume Ive got a wiring issue somewhere. Anyone had this problem, or can throw some adivse my way? Ive had these installed for about 8 months and the color issue has never bothered me, until NOW! Thanks in advance
Steve
Steve
I haven't installed a tach in a while and never tried that one, but here's what I remember.
You should have atleast 4 wires, Ground, Illum, power and signal. Hopefully they went a little above that and did Ground, constant power, switched power and signal. Unless you have a constant power source, it will not remember your settings.
What are your wire descriptions?
Steve
Steve
kontoboy
09-12-2010 10:58 PM
Damonkr
03-25-2010 09:04 AM
BlackJeep
50
06-18-2008 05:22 PM
