Glow shift color change - Ford Truck Enthusiasts Forums
Old 11-22-2010, 09:03 PM
Mydiesel250's Avatar
Mydiesel250 Mydiesel250 is offline
Mydiesel250 is starting off with a positive reputation.
Hey guys, so I've been doing some searching but not comming up with the answers I need. Ive installed glowshift 7 color changing gauges. I can operate the color selection, and the auto change/fade option. However when I set a desired color it wont stay on that color after I turn the truck off? I assume Ive got a wiring issue somewhere. Anyone had this problem, or can throw some adivse my way? Ive had these installed for about 8 months and the color issue has never bothered me, until NOW! Thanks in advance
Steve
Old 11-23-2010, 06:43 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I haven't installed a tach in a while and never tried that one, but here's what I remember.
You should have atleast 4 wires, Ground, Illum, power and signal. Hopefully they went a little above that and did Ground, constant power, switched power and signal. Unless you have a constant power source, it will not remember your settings.
What are your wire descriptions?
Old 06-24-2011, 04:40 AM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
robert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputation
Quote:
Steve
Pics of your install? I have a 2000 Excursion and I am thinkin about the quad pillar with oil temp, oil press, water temp and trans temp.
Old 07-20-2011, 12:44 AM
bigred1992's Avatar
bigred1992 bigred1992 is offline
bigred1992 is starting off with a positive reputation.
Hey, don't mean to jack your thread here, but I have a glowshift tach in my 92. It reads low, anyone else have this problem? Fixes? They sell a signal filter which may help, but I don't know
Old 07-24-2011, 02:53 AM
I havnt been on in a while but heres an update. For one reason or another the gauges couldnt handle the fluctuation in voltage that the truck was putting out. I went to radio shack and bought a $1.60 12v voltage regulator. and BOOM no problems, its been running prime ever since.
Old 07-24-2011, 08:59 AM
bigred1992's Avatar
huh, thanks a lot. I'll have to try that. I have my pillar apart right now to put in a real oil pressure gauge and I thought that I should try to fix my tach as long as I had access.
Buying a USED 6.0L bismic 6.0L Power Stroke Diesel 68 07-12-2016 11:33 PM
Input Courtney Williams 6.0L Power Stroke Diesel 32 01-07-2013 10:43 AM
Engine making a knocking sound jt371 1999 - 2003 7.3L Power Stroke Diesel 7 07-27-2011 09:09 AM
Another 6.0 Hard Start/Rough Idle Thread dscabra 1999 to 2016 Super Duty 9 01-27-2011 09:20 PM
Injector cup removal and replacement Damonkr 1999 - 2003 7.3L Power Stroke Diesel 14 03-25-2010 10:04 AM
Tags
change, changing, color, colors, excursion, ford, gauge, glow, glowshift, guages, problem, shift, stay, truck, trucks, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
