Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 12-31-2006, 01:49 AM
f150andmustang is starting off with a positive reputation.
I have an 87 5.0 Mustang that will not start. It cranks but does not run. I have checked all, fuses, relays, fuel pump, inertia switch. I changed the coil, distributor cap and rotor, TFI Module, fuel filter, and nothing. I am only getting code 34 from KOEO test. I don't know what else to try. Anybody have any ideas? I would greatly appreciate it. Thanks.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 12-31-2006, 02:38 PM
I changed the EGR Valve and it cleared the Error code 34. Unfortunately, it still does not start... My next guess is the ignition switch. Hope it works...
  #18 (permalink)
Old 01-02-2007, 05:55 PM
thelonerangerxlt's Avatar
thelonerangerxlt is starting off with a positive reputation.
f150andMustang, I'd also suspect the TFI/ICM module, but if you've checked or changed it, then look for a CPS sensor near the harmonic balancer. I'm not sure if you have one since you have a distributor, but it's worth a look. If these go bad, you get no spark signal from the ICM.....
__________________
00 Explorer Sport 4x2, 4.0 ohv, 5R55E, 3.55 diff
78 Bronco Ranger XLT, 351M, 4-sp, Trailer Special
  #19 (permalink)
Old 01-02-2007, 06:55 PM
Yes, I have changed the TFI module and nothing. I don't know which is the CPS sensor or harmonic balancer. I think there is a spark coming from the distributor, but still no firing. Most of the time I can figure out what is going on, but this time I am lost. Any other ideas?
  #20 (permalink)
Old 01-03-2007, 09:32 AM
OK, ignore my previous post, I don't think you have a CPS (crank postion sensor) on an 87.
If you're getting a spark from the distributor, it should start if there's fuel. Maybe check the fuel pressure at the fuel rail with a gauge, or remove the air tube at the throttle body, and spray some starter fluid into it while cranking.
If it fires using the starter fluid, then it's a fuel problem, probably a bad pump. If not, then remove a spark plug, ground it on the engine, and see if the plug fires when cranking the engine......
__________________
  #21 (permalink)
Old 01-03-2007, 09:46 AM
Those are good tips. I will try them. Thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
