Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-22-2010, 01:19 AM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
2007 Ford Expedition
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
last question (prob not) about OEM nav
can you inpit destinations while moving, or must the vehicle be in park?
If so, is there a bypass for this?
I've figured out about what I want to get, but am unsure of the nav (dont want to pay for it if it cant be bypassed) I'll go aftermarket then.
__________________
Past rides
06 F250 CC v10 4x4 Lariat bought 5/08 for 20k sold 10/10 for 20K.
RIP BIG GREEN owned her from 08.17.04 - 05.10.08
  #2 (permalink)
Old 11-22-2010, 11:10 AM
TIKT B8 TIKT B8 is offline
Garage is empty, add now
TIKT B8 is starting off with a positive reputation.
Technically the car has to be stopped(or traveling under 5 mph)to input any destinations. But there is a bypass that works great. It takes 2-3 minutes to initially set it up and 3-5 seconds to do once set up.
If you want to use the factory nav unit without the driving restrictions, here are the instructions (from wiingnut here on FTE). Use at your own risk. I have done this and it works great.
1. Take vehicle outside and agree to nav instructions. The gps needs to know its position.
2. Push hard nav button (on right side of radio). Go to your address book. Pick any of one of your saved addresses. Now that address is highlighted, look to right and push soft edit button. You will now see name of saved address.
3. Clear name of saved address and type in F-DEVELOP ON
(make sure to put space between DEVELOP and ON).
4. Now look to the upper left corner and you will see the word ADDRESS. Place your finger directly under the A and hold. If you do this right, the screen should change to the map screen.
5. Now push your hard menu button (on left side of radio). Across top of radio push soft SECURITY button. You have now entered security screen. You will see nothing in the bottom right most corner of nav screen. Push your finger and hold in that position till the screen changes.
6. You now have entered a parameter screen. Locate DRIVING RESTRICTIONS release. When you push the button it should change to driving restrictions stop. Exit the screen by pushing the soft BACK button.
7. Congrats you have just programmed your factory nav radio. NOTE: Every time you turn your vehicle off, you will need to repeat steps 5 & 6.
Good luck and enjoy. If you choose to monkey around with your other parameters, do so at your own risk. I will not be responsible for your dealer service call. If you have any further questions, please pm me and I will do my best to help. This programming sequence should work for only the so called first generation navs. It will not work in the MY09, second generation. This has been used to reprogram many MY 07 and MY 08 Ford vehicles.
__________________
2007 Expedition Limited White Sand
Tags
duty, ford, nav, oem, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
