Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 11-21-2010, 09:20 PM
toolman's Avatar
toolman toolman is offline
1990 Ford Bronco
toolman is starting off with a positive reputation.
Shuts down
The wifes 04 EB Expedition just shuts down while driving at highway speeds. It has the 5.4 and the problem is intermintent and no engines codes. You have to pull over put it in park and it will restart . It will only restart in park I tryed in neuteral but it would not start. It may do this a few times a week. It has 105K on it.
thanks
Tim
  #2 (permalink)
Old 11-22-2010, 11:57 AM
david888 david888 is offline
Garage is empty, add now
david888 is starting off with a positive reputation.
I have had the same issue. When I bought the truck (99 Navigator ) it had a aftermarket sound system in it. I had the issue for about 2 weeks and then decided to change the system out to something more mild. I reran the the power line that was connected near the drivers side kick panel(aftermarket) and was fine. 2 weeks later I decided to run that line again and Bam it stalled on me again. I have since disconnected it and no issues. i called the transmission shop to ask them what the deal was and he told me it might be the ABS Switch on the rear axle or the connector has dirt in it to the transmission(wire harness). He told me to chech the harness and make sure its on tight and is all clean. Its exposed to the elements as well. i have also changed that and no issues at all. Try some of those suggestions and let me know what happens or if you find out what the issue is please post it and let me know what it was. Mind boggling isnt it.
  #3 (permalink)
Old 11-22-2010, 07:12 PM
alloro alloro is offline
alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.
Quote:
Originally Posted by toolman View Post
You have to pull over put it in park and it will restart. It will only restart in park I tried in neutral but it would not start.
Hmm, maybe the range sensor down on the tranny is acting up. The clue is that you cannot start it when in neutral. I'm thinking that if the sensor is acting up and the ECM loses communication with it, the ECM shuts down the engine as a safety feature because it doesn't know which gear to put the tranny in. Just a thought!
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
  #4 (permalink)
Old 11-23-2010, 10:27 AM
Quote:
Originally Posted by alloro View Post
Hmm, maybe the range sensor down on the tranny is acting up. The clue is that you cannot start it when in neutral. I'm thinking that if the sensor is acting up and the ECM loses communication with it, the ECM shuts down the engine as a safety feature because it does know which gear to put the tranny in. Just a thought!
Thats exactly what I was having also. Just as you described .
  #5 (permalink)
Old 11-24-2010, 03:21 PM
bronconvict's Avatar
bronconvict bronconvict is offline
bronconvict is starting off with a positive reputation.
When I had this problem it was on my 2003 navigator. It would stall at highway speeds except I could kick into neutral and turn key all the way off while coasting and restart, then shift back to drive. When it wouldn't restart in neutral I had to safely exit freeway or jump to emergency lane and restart with tranny in Park. In my case it was the relay issue in the GEM module (fuse box). The relay heats up due to bad connection and solder in fuse box on circuit board. The relay itself is the relay which controls PCM. (#41 I think). Dont rule this out as it was a known problem for year (2003)
  #6 (permalink)
Old 11-24-2010, 10:48 PM
toolman's Avatar
1990 Ford Bronco
This may be a dead thread. It seems my FTE account was hijacked. I did not post the root message.
-Scott, '90 Bronco.
Member since 2000
  #7 (permalink)
Old 11-25-2010, 10:13 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
We are working on this...hang in there.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #8 (permalink)
Old 11-25-2010, 07:20 PM
mayor mayor is offline
mayor is starting off with a positive reputation.
Sorry
I figured out I was wrong on my user name. I use toolman on a lot of other sites and was sure I had used it here. But I had not posted in a long time and changed my email address. So I ask the administrator to give me a new password and gave assurance I was toolman. I apoligize for any problems I may have caused.
Sorry!!!!!!!!!!!!!!!!!!!!!
Tim
  #9 (permalink)
Old 11-25-2010, 07:22 PM
We still have the problem with the 04 Expy
  #10 (permalink)
Old 11-25-2010, 08:00 PM
Quote:
Oooooooooooooops!
__________________
  #11 (permalink)
Old 11-27-2010, 02:59 PM
toolman's Avatar
1990 Ford Bronco
Figured it was something like that....good luck with your truck !
-Scott
  #12 (permalink)
Old 11-30-2010, 04:30 PM
Had a (ford) mechanic tell me when a cylinder miss fires the PCM shuts the fuel down causing the engine to die. You can restart because the PCM is reset when you turn the key off and back on.
He said to replace the plugs and if it still does it replace every coil. He said coils start to break down after 65k??????? My 1999 F150 has 155K and the orginal coils.
What do you think?
  #13 (permalink)
Old 12-02-2010, 08:46 AM
2trux 2trux is offline
2trux is starting off with a positive reputation.
It seems pretty unlikely that a misfire would cause the engine to shutdown without a code. When I had a coil go out it misfired, and gave a code, but continued to run until I replaced the coil. This advice seems like an expensive shotgun fix.
  #14 (permalink)
Old 12-02-2010, 04:35 PM
I didn't beleive it . But will change the plugs and fuel filter and see what happens their due to change anyway. The no code is what has me puzzled.
  #15 (permalink)
Old 12-02-2010, 05:20 PM
05ford expy 05ford expy is offline
05ford expy is starting off with a positive reputation.
Had the same problem
We had the same problem with our 05 Expedition. First there were no codes, then the service engine light came on so we took it to a garage they said it was #7 Spark Plug, so we changed the spark plugs...a spark plug broke. We were still driving it and then on the highway started losing power...at about 65 mph, stalled and pulled over to restart. We then parked the vehicle ordered a special tool to remove the broken spark plug thinking that it was the spark plug causing all this chaos, and a few days later tried restarting it-it wouldn't start. We then decided to take it back to the garage and had it towed. We found out it was a "smartbox". Replacement cost-$250, labor $250. I've been googling what the heck a smartbox is...can't find anything!!
Good Luck with your problem!
Tags
00, 2005, drive, driving, expedition, f250, ford, half, lincoln, navigator, restarts, shuts, smartbox, sport, start, tank, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
