Hella Optilux replacement bulbs, Anybody use them? - Ford Truck Enthusiasts Forums
Old 11-21-2010, 05:50 PM
Fandini Fandini is offline
Fandini is starting off with a positive reputation.
My OEM headlights are not as bright as I think they should be. Did some looking around and saw these bulbs on Hella's site. I have had really satisfying experiences with Hella products. These bulbs are a higher wattage than standard OEM bulbs so I was wondering if anyone has any experience with these bulbs or any info on them. Thanks!
Old 11-21-2010, 08:16 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
What bulb do you run?
Hella is pretty good stuff, but I loved my PIAA Extreme white plus bulbs. They are on the pricey side, but the technology is worth it. The 9008 OE harnesses and alot of the 9007 harnesses don't handle the extra amperage of high out bulbs so well. The Piaa's pull stock wattages but produce more light. The cheap white bulbs were often voltage sensitive, and all but required a relay harness, but the harness did eliminate the OE plug problem.
Old 11-21-2010, 11:38 PM
What kind of bulb do I run? I think it's an H13, but I have to look to be sure. The Hella Optilux is a higher wattage bulb, 80 and 100 I think. I like the standard halogen color which seems to have a little yellow hue in it as opposed to the bright white color of some of these other bulbs.. I just would like more of it. The super bright white colors I've seen on many of these bulbs seem to strain my eyes.
Old 11-22-2010, 05:11 PM
ReAX's Avatar
H13/9008 is in pretty much anything new. The OE plugs for those were finicky, I read a lot of stories on the internets(so they had to be true) about high watt bulbs melting the plug. Just something to be aware of.
Old 02-22-2011, 07:41 PM
Rick4345 Rick4345 is offline
Rick4345 is starting off with a positive reputation.
lights
Try Sylvania Silverstar bulbs. I have used them in all my vehicles and been very happy. I like them so much I even put them in my squad car. I also have them in a BMW 328i and am about to put them in my 2010 F-350 Super Duty I just purchased. They also have a great line of replacement bulbs for turn signals and the such. Plus, they can be found pretty much anywhere.
My first X, the ups and downs BlowNdoh Excursion - King of SUVs 15 07-30-2014 08:22 PM
2002 Recon projector lights moyer h 1999 to 2016 Super Duty 0 06-30-2013 09:16 PM
Anyone tried Hella HB5 bulbs snowdog79 2004 - 2008 F150 1 12-06-2010 08:57 PM
Will these bulbs melt my OEM fog lights? Wagion 1999 to 2016 Super Duty 2 10-13-2009 01:29 PM
Cheap headlight upgrade soutthpaw Excursion - King of SUVs 7 02-11-2009 10:47 AM
Tags
bulb, bulbs, f150, headlight, hella, hellas, kind, navagater, oe, optilux, plug, raptor, replacement, technology, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
