replacement cab mounts
Hi Troy -
I just finished installing new front cab supports and floor pans on my '66 Ford F100. I used replacement parts from Dennis Carpenter and am very pleased with them. Last timed I checked, everone else makes the stamped cab supports that are designed to just wrap around the old cab supports. Structurally, they are nowhere close to the factory replacements. The DC parts are not cheap, but you get what you pay for.
Good Luck!
Dan M.
Good Luck!
Dan M.
I used the cab mounts from LMC. They are designed to fit over the old ones and mine matched up great. I cut my old mounts off for the most part. I couldn't totally remove without cutting into the pan. I think the mounts cover several years, so and are really long. I cut my down to fit better before welding. I had to do some hammering to get it all down good.
I just don't enjoy welding thin metal , but got the job done!
troy's66customcab
03-19-2011 12:27 AM
troy's66customcab
02-13-2011 04:00 PM
