Bars Leaks block sealer? - Ford Truck Enthusiasts Forums
View Poll Results: How should i fix a minor leak?
Fix it right, new head gasket 9 56.25%
Fix it cheap, block sealer 7 43.75%
Voters: 16. You may not vote on this poll
Old 11-20-2010, 08:45 PM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
Please read before voting
Not diesel related, but i like you guys and the nissan forum is damn useless...
My Sentra has a very slight leak at the head gasket on #4. Pressure into the cooling system and coolant out of the motor. It's not much, its not running hot, and it still runs great, but it's there...
Now the way i see it I can fix it right, or fix it cheap. The car has almost 228xxx miles, uses no oil, and is rusty as crap.... It's not worth much and i don't want to put a lot into it and i don't really have the time to put a head gasket on, but if theres no option i will...so....
Has anyone use the Bars Leaks block sealer? What was your result?
Old 11-20-2010, 09:25 PM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
bars leak no!!
risoline head gasket fix yes!!
in the heading i voted no because i thought it was for a diesel. nissan or similar, yes. compression is too high for diesels like ours for that stuff to work permanently.
Old 11-20-2010, 09:39 PM
Otahyoni's Avatar
Got a link wreckin? I just want alternatives...
Old 11-20-2010, 09:51 PM
Rislone Head Gasket Fix
RxAuto Head Gasket Repair | Blown Head Gasket | Call 1-866-780-9042
Irontite Sealers and Additives
The above three i would use over anything esle for a car or gasser engine. diesel absolutely not.
Old 11-20-2010, 10:06 PM
Otahyoni's Avatar
Wreckin, i like that Rislone a lot better.... no flushing the system, leave it in... sooo much simpler!
Have you used it before? How quickly did it work?
Old 11-20-2010, 10:12 PM
Otahyoni's Avatar
OK, weird....
Same thing?
Bar's Leaks Head Gasket Fix
EDIT: MSDS comfirms they are the same thing. Just a difference in marketing.
Old 11-20-2010, 10:31 PM
bars leaks and risoline are like chevy and gmc. just different names, same product.
as for the stuff, used it in my buddies 93 civic and it sealed it up in 3 minutes of idling. but with the easy use ones, there is the above mentioned and the irontite all weather seal, both are coolant friendly and work well.
Old 11-20-2010, 11:26 PM
ihateminimumwage's Avatar
ihateminimumwage ihateminimumwage is offline
ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.
I almost put 'fix it right', but made sure to read the first post before voting. On a beater Nissan, use the sealer.
Old 11-21-2010, 12:05 AM
Country_boy_2007's Avatar
Country_boy_2007 Country_boy_2007 is offline
Country_boy_2007 is gaining momentum as a positive member of FTE.
on a little beater car like that, id go with the sealer, if it was something worth puttin the money into id fix it right. go with the sealer
Old 11-21-2010, 07:11 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
Old 11-21-2010, 07:37 AM
Otahyoni's Avatar
Mistaken, while it's much cheaper than a shop repair bill, that steelseal costs half as much as the head set...
I'll pick up a bottle of the coolant friendly Bars Leaks and see what happens.
This is just a winter beater anyway...
Old 11-21-2010, 07:41 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
never used either, but i have used blue devil Blue Devil Engine and Cooling Sealant (32 oz.) - BLU38386
works fantastic.
you need to thoroughly flush the system.
for a rusty beater, i probably would not use it, but for a good vehicle, well worth the money spent.
Old 11-21-2010, 07:50 AM
Yep, it's not cheap but it works and a whole lot less time consuming than replacing a weeping gasket. In their FAQ: We guarantee it for as long as you own your vehicle. No other product on the market has a guarantee like ours.
Someone a few years ago posted about using the stuff and said it worked great. That is when I decided to try it on a chevy 454 to fix a weeping plastic intake. Worked fast, no more wet spots, has been in for around 2 yrs. My dad then bought some for his Pontiac with the AGAIN plastic intake and it fixed that one with over 100,000 on the engine. Stupid plastic intakes!
Old 11-22-2010, 08:07 AM
Bar's Tech Support Bar's Tech Support is offline
Bar's Tech Support is starting off with a positive reputation.
Hey everyone. We saw this discussion about our block sealer and wanted to say hi and see if we could help any further.
Our 1111 and 31111 products are the same formulation; they are different in terms of marketing/packaging because we sell into different geographies under different brands. So, you are correct in saying they're the same.
Both products have been immensely popular over the 24 months, and we stand behind them as solidly as anyone. In fact, here's a whole page of testimonials from real people about the 1111 product.
If you have questions before you use either 1111 or 31111, PM me or call 800-345-6572 x 204. Ask for Fred. Will be happy to help any forum member in any way we can.
Thanks everyone.
Old 11-22-2010, 09:09 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I did use the Bar's leak head gasket fix on our Cummins, it had coolant leak stains down the side of the block, not compression leaks, just coolant leaks, and it does seem to have taken care of it for now. Eventually the head gasket will get changed, but it is working for now, and it wasn't like it was a big leak anyway. If it was totally blown out, I doubt I would have tried at all. My uncle had a 454 that was starting to go, put the fix in and it got him home from Pennsylvania to Texas. Permanent, likely not, but seems to be a good temp fix to get you home, which many of these products are for.
Cavitation or head gasket? Block sealer? idiguy90 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 08-05-2015 08:37 AM
Rear Main Seal Leak fasthauler 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-13-2012 10:39 AM
Gasket Sealer on Intake Manifold Gaskets Matt Wilson Performance & General Engine Building 32 12-29-2011 01:14 AM
How do you seal your gaskets? RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 4 12-07-2011 01:33 PM
How to Use DICOR (self-levelling EPDM sealer) Greywolf Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 1 07-16-2008 08:38 PM
Tags
32, bars, block, blue, carbon, cooling, devil, engine, fiber, fix, gasket, head, hg1, leak, leaks, msds, oz, sale, sealant, sealer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
