Power Windows for 1954 F100 - Ford Truck Enthusiasts Forums
Old 02-28-2003, 01:07 PM
medicpg's Avatar
medicpg medicpg is offline
medicpg is starting off with a positive reputation.
Does anyone know a good donor vehicle for the power window hardware for a 1954 Ford F100? I would like to grab the motors and related parts from the Junkyard and save some $$
Old 02-28-2003, 03:11 PM
DS02F250 DS02F250 is offline
DS02F250 is starting off with a positive reputation.
Not sure of a good donor vehicle, but with all the room inside the door of a '54, you probably could just measure the width of the bottom of the rail lift and go hunting for almost anything. You'd still have to fabricate mounts and brackets to hold it onto the inside of the door, plus wire it, get switches, etc, etc, etc.
In the long run, you might be better off contacting A-1 Electric and see what they have: www.a1electric.com
At least then you know you're getting something new, that works, is pre-wired, and will install easily versus trying to ramshackle your way into PW's.
Daryl
Old 02-28-2003, 04:26 PM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
Unless you get something direct fit, aftermarket power windows are a big pain to install. My experience is limited to two different kits. They were both very time consuming, requiring fab of every bracket.
Old 02-28-2003, 11:38 PM
truckfarmer truckfarmer is offline
truckfarmer is starting off with a positive reputation.
I haven't done the swap myself but have been told that the power windows from a Chrysler mini-van is the same as the aftermarket kits.
Old 03-01-2003, 07:51 AM
mercuryblues mercuryblues is offline
mercuryblues is starting off with a positive reputation.
if your windows go straight up and down Hyundai Steller rear power windows work great. They are 2 wire motors (reverse polarity for up and down ) same as GM so you can use GM switches. I used them in my 59 Merc.
1954 F100 Heater Box medicpg 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-04-2014 01:31 PM
Seat belts for 1954 F100 medicpg 1948 - 1956 F1, F100 & Larger F-Series Trucks 47 08-11-2014 08:04 AM
Tires for 1954 F100 1954_NJ_F100 WTB - Ford Trucks & other vehicles 0 08-04-2014 07:49 AM
1954 F100 Power Window Install-need advice medicpg 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 07-14-2011 05:16 PM
Putting power steering on 1954 F100 truck Fat Fendered Ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 11-27-2002 05:12 PM
Tags
1954, 1954f100, 54, electric, f100, f1oo, ford, install, power, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
