Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 11-20-2010, 06:01 PM
john19999 john19999 is offline
Garage is empty, add now
john19999 is starting off with a positive reputation.
P0125 Navigator 2000 coolant temp low ?
Navigator 2000 got Service Engine Soon with code P0125. That means Engine coolant Temperature always low. The navigator dashboard shows temperature on dashbord around 25% above cold when driving for about 10 minutes. The temperature rises from C towards H but stays around 20% to 25% but never goes up. Navigator runs fine. It could be thermostat bad or Engine Coolant Temperature Sensor.
Do you know where is temperature sensor located? How to test it? Any experience with this code?
Thanks
John
  #2 (permalink)
Old 11-20-2010, 06:09 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
It would seem that you may have an air pocket in the engine. The gage will not register if the coolant is not touching the sensor. There is also the possibility that the wrong thermostat is in the engine, possibly a 165* would cause the gage to register a low temp.
  #3 (permalink)
Old 11-20-2010, 06:30 PM
Moto Mel,
Thanks. Do you know how to test Engine Coolant Temperature Sensor. Where is this sensor located?
Thanks John
  #4 (permalink)
Old 11-20-2010, 07:14 PM
alloro alloro is offline
alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.
Your t-stat is the problem. You can rule out the temperature sensors as the problem because both are reading low. There is one for the gauge and the gauge is on the low side, then there is a second one that reports temperature to the ECM. The ECM also thinks the engine is to cool because it is giving you a low temperature code. It's unlikely that both sensors would go bad at the same time, so the common part between the two is the t-stat.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
  #5 (permalink)
Old 11-20-2010, 08:48 PM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Replace the thermostat with a new Motorcraft unit, refill the system with a 50/50 mix, and be done with it.
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #6 (permalink)
Old 11-20-2010, 09:36 PM
kerim1 kerim1 is offline
kerim1 is starting off with a positive reputation.
i had the same problem with my 2000 expy. it was the T-Stat
  #7 (permalink)
Old 11-20-2010, 09:48 PM
Moto Mel's Avatar
Quote:
A lot of "Old Schoolers" put a lower value thermostat in as that is what we are familiar with; 160* summer and 185* winter. With these engines we must stick with the factory settings in order to get maximum efficiency from our engines. The wrong thermostat sends the info to the ECU which then tells the fuel and ignition systems what to do and the info it gets will determine the way it runs and the mpg we get.
  #8 (permalink)
Old 11-21-2010, 03:38 AM
Whatif I keep driving navigator with P0125 code (bad thermostat - temperature low). The heater is working quite fine and gauage shows about 20% above cold. Is there any harm to Engine if I keep driving navigator?
Thanks
John
  #9 (permalink)
Old 11-21-2010, 06:25 AM
Quote:
Thanks
John
Yes. The engine will stay in open-loop warm-up mode longer than it should. This will waste fuel, raise emissions, and increase the possibility of damaging the cats from excessive raw fuel.
__________________
  #10 (permalink)
Old 11-21-2010, 07:23 AM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
It sounds to me as if the thermostat has failed in the open position.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #11 (permalink)
Old 11-21-2010, 08:26 AM
Moto Mel's Avatar
Quote:
If that's the case he is very lucky, I've had 2 that stuck in the closed position and I was fortunate to be close to home and not hurt the engine or blow any gaskets.
Tags
2000, 2003, chevy, code, coolant, expedition, ford, impala, lincoln, navigator, p0125, po125, sensor, temp, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
