Vibration/grinding Dana 44
'86 F150 with factory Dana 44 w/ manual locking hubs. I flushed my TC since winter is coming up. I used Castrol Dex/Merc ATF. When I test drive after, there was a harsh vibration/grinding in 4x4 from the front end. Last time I used 4x4 a few weeks ago I didn't notice this. I was pulling a trailer out of the woods and up a steep hill, that could explain why I didn't notice it if it was there before.
In 2WD there is no problem at all. But, with the manual hubs locked, regardless of transfer case gear, there is a bad vibration/grinding, even a high pitched squeak from the front end. I topped off the front diff with a 1/2 quart - no difference. It acts/sounds like a wheel bearing or U joint to me. I am not familiar with 4x4.
I didn't see anything obvious - all the front U joints look very old, even have a little play, but they're not falling apart. I need some direction and advice. Thanks!!
I checked it out today. My tires are all the same brand and tread, but they're all choppy, feathered, and have different tread depths. I rotated them so that the rears have 6/32" and the fronts have 10/32" and 7/32". Before the right tires were low tread and the lefts had more tread, which probably caused problems engaging the front hubs. The seem to be properly engaging/disengaging now. However, I do need several u-joints throughout the drivetrain. They're not terrible, but should be replaced.
I am going to replace all the front axle u-joints. Any recommendations for a good brand?? Also, I will replace the front rotors and bearings. Recommendations for quality parts??
RocK Auto only carries ACdelco and Precision. I got on drivetrainspecialists.com and clicked on u joints. 80 different u joints came up and their website is so poorly designed that I could not figure out how to narrow them down for app specific u joints. I shot them an email asking for the POs. Geesh, I just want some quality u joints.
kyle1979ford
05-29-2013 09:21 PM
LincolnFord
1999 to 2016 Super Duty
17
12-05-2008 12:55 PM
