Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-20-2010, 11:40 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Want to make a more efficient Condenser.
Just wondering if anyone has plans to share. I use a "Plumbers Delight". It works, but the vapor coming out when the oil is at 185 or higher is still pretty hot. I think if I can get a more efficient one I should be able to recover more Methanol. (recover about 1-1.5 gallon per batch now)
On a seperate note, I am getting foam toward the end of the distallation process. Is this a seperate issue? At around 185 degrees, I shut off the heat and let the pump continue to circulate the hot oil to get more Methanol out as the oil cools. I am using a GL eco-processor at present, and have tried closing the vacuum valve also, but still got the foam. thinking next batch will shut off the pump and just let it cool with the condensor going...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 01-08-2011, 09:57 AM
KEITH69RANGER KEITH69RANGER is offline
Garage is empty, add now
KEITH69RANGER is starting off with a positive reputation.
i have made cooler/condenser(tube in tube) for other fluids, not sure about compatibility with methanol. take compression or pipe Tee, larger outer wall and connect. the end compression fittings, either drill or reem out stop for tubing to allow tubing to slide thru. you can adjust angle of tube to control rate of cooling. i have used water hose flowing around outside to funnel with icewater feeding in with hose bib valve to allow to drip thru. you cna also use to heat fluid. simple and can be fabbed with hose, PVC or metal tubing/pipe.
  #3 (permalink)
Old 01-10-2011, 12:03 PM
Rushmore X's Avatar
2003 Ford Excursion
Welcome to the forum. have any pics?
__________________
Tags
1961, 73, ac, block, condenser, condensers, cqn, delight, diesel, efficient, engine, f100, forum, hot, make, plumbers, small, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
