1995 F-150 Speedometer/Transmission Issues - Ford Truck Enthusiasts Forums
Old 11-20-2010, 11:03 AM
vanduker vanduker is offline
vanduker is starting off with a positive reputation.
I am troubleshooting a neighbors F-150. Is a 5.8 automatic with ~ 75k miles.
The speedometer stopped working, transmission started shifting hard and O/D light on shift column started blinking.
I changed the sensor in the rear end housing as the ohm value between it and the new one were substantially different. No change.
I was out for a few days so they took it to a dealer who diagnosed a bad dash cluster. The neighbor bought a salvage (believed to be good) cluster which I installed last night. No change other than the temp gauge in the replacement cluster works where the old one did not.
I'm looking at http://www.ford-trucks.com/forums/10...eedometer.html
On this truck if I hold down the reset button on the dash (the reset for the odometer) and turn the key to run - nothing happens that is different from the normal - no gauge sweep, no display at all in the mileage window.
Is this likely another bad gauge cluster? I'd sure appreciate any help.
Old 11-20-2010, 12:26 PM
Xclimation's Avatar
Xclimation Xclimation is offline
Xclimation is starting off with a positive reputation.
Based on my experience (assuming you have the cluster that has the PSOM):
Yes, I went through 2 junkyard PSOMs until the third one worked!
Good luck!
Post back if and how you fixed it.
Old 11-20-2010, 02:16 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Not sure but i thought the 95's used the rear diff sensor only for the ABS nonsense & there was a second VSS on the side of the trans for the speedometer.
Could be wrong though.
Old 11-20-2010, 03:17 PM
87 XLT now I am confused. From what I had read I thought this truck used the rear sensor but now I also see the parts book lists one for the transmission though it shows it on the driver side rear of the trans and I do not see that on this truck. It also lists different ones if it is an analog or digital dash - this one is a digital odometer but everything else is analog - is that a digital or analog dash?
Would this sensor being bad keep the odometer from displaying anything at all?
This is what makes me think it is just the one in the rear:
http://www.fordf150.net/forums/viewt...99d78&start=15
Old 11-20-2010, 05:22 PM
If I had a 95 F-150 I would also have the FACTORY wiring diagrams for it & could tell you for sure how it's wired.
But, if you're not finding a VSS on the drivers side trasmission tail shaft then it must use the rear diff VSS for ABS/speedo/cruise control..
speedometer tfink3 1997 - 2003 F150 0 12-17-2015 12:54 PM
Instrument cluster ramsay Excursion - King of SUVs 9 02-09-2013 12:58 AM
HOWTO: 81-86 gauge cluster in 80 model (gauge models ONLY!) Rogue_Wulff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 03-19-2012 08:38 AM
96 F150 gauge cluster mrgn_mtt 1987 - 1996 F150 & Larger F-Series Trucks 2 05-10-2011 10:36 PM
98 speedometer reads 100 when i get over 20 mph boarhawg 1997 - 2003 F150 4 04-07-2011 10:34 AM
Tags
1995, bad, f150, ford, fordtruck, molular, problems, roush, speedometer, speedometers, stopped, transmission, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
