Duraspark II Conversion - How To
Old 12-27-2014, 01:36 PM
jack orchard's Avatar
jack orchard
jack orchard is offline
Make a New DSII Harness
Originally Posted by Gary Lewis
How are you going to have an easily-repairable ignition using Weatherpaks when all the ignitions you'll buy have the Ford connectors?
The main point of using Weatherpak Connectors or new aftermarket Ford connectors is to insure reliable, dependable connections. I think Weatherpak Connectors produce a neater, more professional looking job than the Ford connectors. 30+ year old connectors and associated wiring are way past the point in time that they can be relied upon. New wiring and connectors is best (in my opinion).
Replacement Ford type connectors can be purchased from many auto supply places, as well as Rock Auto (my favorite). Good luck,....jack
  #167
Old 12-27-2014, 02:54 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
I agree that the Weatherpaks are better, but I don't want to have to graft them on in the middle of nowhere if the ignition box dies.
  #168
Old 12-27-2014, 03:25 PM
ruglyot's Avatar
ruglyot
ruglyot is offline
Cut and splice! Yes, the Weatherpak idea is not for everyone - but my 20 years in GM parts and custom motorcycle wiring has me a bit biased. This is my first Ford, but I've always noticed over the years how easy it was (for me) to always break the lock tabs on Ford electrical connectors or how it always took three screwdrivers to release the darn things! So, that's the reason I'm using these on mine - but someone else making their own harness should still keep in mind the value of a good electrical connection. It's one thing to connect the two points correctly, but if both terminals aren't crimped and/or soldered firmly and properly, you may spend more time diagnosing than it's worth as opposed to finding and buying a correct harness.
I'm really not trying to talk anyone out of making their own harness - because it really is within anyone's ability - but I wanted to offer some points of view to use in your own design process (and yes, I may have a little OCD!) Russ
  #169
Old 12-27-2014, 06:32 PM
6978sghfbjklgdfsjhkl's Avatar
6978sghfbjklgdfsjhkl is offline
I'm in the process of converting my duraspark installs to weatherpak connectors..along with any new "spare" I will have on a road trip, that way..it will still be "plug'n play"...
  #170
Old 12-27-2014, 06:56 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
That'll work. Or, carry a Weatherpak/Ford conversion cable so you can buy a new module and plug it in.
  #171
Old 12-28-2014, 09:31 PM
JimsRebel's Avatar
JimsRebel
JimsRebel is offline
Info on how to use the DS2 harness you currently have is here...
https://www.ford-trucks.com/forums/7...-150-woes.html
You will just cut the coil positive wire near the gray square plug and splice it to your current harness. The rest will just plug in.
Jim
  #172
Old 12-29-2014, 07:22 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
FWIW, I believe the wiring harness that I used on my '84 conversion was out of a '77 or a '78 with a 300 I6. No cutting or splicing. Just 100% plug-and-play by matching the plug shapes. I think the troubles start to come when you get one from a V8.
  #173
Old 12-29-2014, 08:17 AM
adperk94's Avatar
adperk94
adperk94 is offline
Jim,
I read through the thread that you linked above, am I understanding correctly that I can separate the wiring for the coil, module and dist. out of the '78 harness and combine that with the water temp. and oil psi portions of my '85 harness?
  #174
Old 12-29-2014, 08:50 AM
JimsRebel's Avatar
JimsRebel
Originally Posted by adperk94
Jim,
Yes that is correct, just one splice for the coil feed wire.
Jim
  #175
Old 01-03-2015, 01:18 PM
JayzDaddy's Avatar
JayzDaddy
JayzDaddy is offline
Anyone have the missing pics from the beginning of this thread? Its what im lookin for but the pics wont show.
  #176
Old 01-03-2015, 01:49 PM
Sean_Memphis's Avatar
Sean_Memphis
Sean_Memphis is offline
What do you need pics of?
  #177
Old 01-03-2015, 03:44 PM
JayzDaddy's Avatar
JayzDaddy
Wires to remove and computer location. Im wanting to clean the bay up.
  #178
Old 01-03-2015, 04:12 PM
Sean_Memphis
The computer is under the dash on the drivers side w/the wiring harness coming out and going through the firewall...all of that comes out.
  #179
Old 01-04-2015, 09:13 AM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
Try this thread:
https://www.ford-trucks.com/forums/1...swap-help.html
  #180
Old 01-04-2015, 09:47 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Originally Posted by LARIAT 85
Thanks, Fonzie! I think I'll replace the URL in the Sticky with the one you just gave, as it still has pictures....
Quick Reply: Duraspark II Conversion - How To
