rebuilt 4.9 will not idle with vacuum line connected
We have a rebuilt 4.9 carb motor that will not idle with the vacuum line hooked to the brake booster attached . could the carb be the problem? I will be grateful for any suggestions. Thanks
Could also indicate that you have the throttle blades or choke closed too far and the engine is struggling to idle when you take away a source of air that it is actively using.
