Duraspark II Conversion - How To - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 06-12-2014, 06:54 PM
Sean_Reno Sean_Reno is offline
Sean_Reno is starting off with a positive reputation.
Updated pics.
  #122
Old 06-12-2014, 07:04 PM
DSII DIST. and ICM
DSII ICM
New Carb.
These are the install pics, that I had handy on my phone.
  #123
Old 08-18-2014, 11:28 PM
target1001 target1001 is offline
target1001 is starting off with a positive reputation.
More Info
Wanting to convert to DSII and I have read through the miles of threads. I still have a couple of questions I am curious about. I assume this dizzy is vacuum primary and mechanical secondary advance. If so, what does the control box actually do. It was said timing was reduced at start but don't understand how. Second, does anyone know what the total secondary advance is, and is there recurve kits available for this dizzy?
  #124
Old 08-18-2014, 11:50 PM
ghostshark ghostshark is offline
ghostshark is starting off with a positive reputation.
Quote:
Well on this one all I know about the dizzy is its called a single vacuum advance. Ive
I used the GM 350 4 pin module from a 1980 corvette. I personally hate the big box under the hood so I custom made the heat sync and mounted it to the firewall.
What it does for you is instead of going with a computer controlled carburetor with a ton of sensors like the MAP and O2. You can either go for a point based system requiring constant adjustment, point failure and a ballast resistor "quiver" to reduce the 12v to ~9 and using an oil cooled coil that has a tendency to leak and fail. Or you get to use a solid state ignition module, tfi 12v coil for more ponys and a magnetic dsII dizzy that never fails.
All that and you don't need a computer the system it just needs 12v to the module which powers the coil. Rock solid cheap ignition that never fails just like the i6 itself.
Go for a cam, carb, intake and exhaust first and if you think you still need to recurve the dizzy then you can do it after I would say.
  #125
Old 08-18-2014, 11:55 PM
Quote:
Originally Posted by bill06447 View Post
Where/how did you mount the GM HEI module? ~Bill
I'm so sorry bill I missed your question by a mile.
To answer I mounted it to the side wall just behind the washer fluid reservoir.
I posted a pic of it somewhere I'll see if i can find it for you.
[IMG][/IMG]
and
[IMG][/IMG]
  #126
Old 08-19-2014, 08:27 AM
1986F150six 1986F150six is online now
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Very neat installation, ghostshark!
  #127
Old 08-19-2014, 07:55 PM
bill06447 bill06447 is offline
bill06447 is gaining momentum as a positive member of FTE.
Nice! (Love the mini air filter btw) ~Bill
  #128
Old 08-28-2014, 06:08 PM
1984Ford300six 1984Ford300six is offline
1984Ford300six is starting off with a positive reputation.
Hey buddy, i know this is a 4 year old post, but i got in WAAAY over my head on my 84 duraspark 2 swap. i gutted out all the emisson and wire harnesses for the TFI ignition and i have the module and coil. coil is installed with correct wire from dizzy. im stuck on the wire harness i need and where the plugs go in on the module and distributor... HELP PLEASE
  #129
Old 08-28-2014, 06:13 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Quote:
Hopefully Chris, or one of the other mods, will be along to move this to your own thread. That way you'll get the attention you need. And I'll watch for it and join in.
  #130
Old 08-28-2014, 06:51 PM
A little help, if it helps.
Im not sure how much help I can be here because I did the DSII distributor but I used a gm 350 4 pin ing module to run the system.
If you want to run that dirt cheap ignition mod here is the link of it. I hope it helps
Better Dirt Cheap Electronic Ignition
Good luck!
  #131
Old 08-28-2014, 06:53 PM
Air filter
Hey there Bill just a heads up on the air filter.
You can get that at ANY oreillys. Its actually meant for a lawn mower but they all have it in the back. If I find the part number Ill post it. But it is there and they all stock the filters too!
  #132
Old 08-28-2014, 07:33 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
You should have a single plug on the distributor, a few plugs (two or three, can't remember) coming out of the firewall on the driver's side, and then a few plugs coming out of the ignition module.
The wiring harness connects the plugs coming out of the firewall to the ignition module and distributor.
From my experience, you cannot connect these wrong. The plugs ONLY fit one connector and they're all keyed so that the correct plug can only go in the right place.
If it fits, plug it in. Keep going until all the plugs in the harness are in a connector.
Then, the longer wire goes around the back of the engine to the passenger side to the temperature sender, and the shorter wire goes to the oil pressure sender on the driver's side of the block.
  #133
Old 08-28-2014, 07:51 PM
AbandonedBronco = Life saver .
Thanks man.
  #134
Old 08-28-2014, 07:54 PM
Also, One more question. Theres a 79 F150 with the DS-II ignition. but its a 302. are there distributors compatible with the 300? or will i have to pretty much find a 300 with DS-II to yank that dizzy
  #135
Old 08-29-2014, 12:00 AM
I did the DS II swap on my 85 F150 w/4.9. It went very smooth. I bought a reman distributor at Auto Zone and pulled the ignition harness out of an 82' F150 at the local Pick N Pull. I got lucky and the truck had an OEM Ignition Module and Coil (Canister style for DS II). I of course also swapped the carb out for a non-feedback/mechanical one.
You just have to install the DS II Distributor (hook-up vacuum advance) and wiring harness connects to coil and ignition module (box) on fender. PM me w/any specific questions you might have or if you want pics.
HOWTO - DSII Conversion (swap from TFI or EECIII / EECIV to DSII) ctubutis '80-'86 HOWTO's 2 05-21-2015 09:18 AM
Electrical Plugs Photo's and Q's 1983F1503004x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-05-2011 02:06 PM
Got Truck: '78 F150 SWB! XxWINxX94 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-18-2011 07:58 PM
My recent Mod's, Bull Bar, Fog Lights, CB Radio, Back Up Camera, Reverse Lights brd7666 1999 to 2016 Super Duty 15 11-09-2010 08:33 PM
OT?: Detailing the Ex...pics inside ajorn Excursion - King of SUVs 22 03-02-2010 02:26 PM
Tags
1986, 460, conversion, duraspark, f150, flathead, ford, georgia, i6, ii, parts, picture, plugs, spark, upgrade, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
