Duraspark II Conversion - How To - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-04-2014, 11:46 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Originally Posted by Sean_Reno View Post
So, anything w/the I6-300 (vans, Broncos, F-Series) will be a direct fit?
Assuming it uses the blue-grommet Duraspark II module, yes. DSI and DSIII modules don't count; California-emissions-equipped vehicles don't count.
  #62
Old 02-04-2014, 11:49 PM
Sean_Reno Sean_Reno is offline
Sean_Reno is starting off with a positive reputation.
I can solder, but if I have to buy one from a yard, then I want it to be a direct-fit.
  #63
Old 02-04-2014, 11:57 PM
ctubutis's Avatar
I understand... But doing that is necessarily going to lengthen the amount of time it takes to find a "good" one. You see, much of the wiring I've run across in junk yards is crap - exposed copper wires, melted insulation, broken connectors, hacked by a PO, etc.
Do what you want and I can appreciate wanting the direct-fit (I'm generally the same way) but the fact remains it's likely going to be a while before you find exactly what you want.... you have been warned.
  #64
Old 02-04-2014, 11:59 PM
Quote:
How can I tell, if they are Something other then DSII...won't vehicles withe the 2-plug Blue Module...be DSII??
  #65
Old 02-05-2014, 12:10 AM
ctubutis's Avatar
That's a good question....
DSI came about in the mid-70s IIRC (1975 sounds about right) so don't use anything from pre-1977... I seem to recall the DSI modules looking very much the same but my memory of them is hazy and I certainly don't remember the specifics, just avoid it if it's questionable.
DSIII Came out in 1980 *mostly in California vehicles* (and possibly high-altitude configurations but this is another thing I can't be positive on) and EEC-IV came about in 1984.
Best thing I can offer is, yes, the two-plug, blue-grommet box 1977-1983 49-state is what you are looking for, avoid anything else.
  #66
Old 02-05-2014, 12:17 AM
I accept the warning...I'm not in a super hurry, to find a harness. I will wait to find one from an I6. I've actually found a couple online, but they wanted me to buy the whole engine harness $100+ shipping.
  #67
Old 02-05-2014, 12:42 AM
Using an MSD Box, I have on my shelf is another option. I'm just not sure what I would remove/keep with this set-up.
  #68
Old 02-17-2014, 05:59 AM
I have an 85...does anyone know what year trucks, I need a harness from (78-79...look different)??
  #69
Old 02-17-2014, 10:28 AM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is online now
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
For a proper fit without modifications, you will need a harness from a 1980 - 1983 F100, F150, or Bronco that has an I6 engine. [Except for California models that used Duraspark III] these years still used Duraspark II.
Be aware that some models had a tachometer, and some didn't. A harness for a truck that has a factory tach on it will have an extra plug, and the ones that didn't have a tach will not have the extra plug in the harness.
Capiche?
  #70
Old 02-17-2014, 12:57 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Capiche?
I don't believe this is correct. The wiring harness is pretty much the same from about 76/77 - 83.
The wiring harness in my '84 came from a 78, I believe.
Not only that, but nothing is different between a tach and a non-tach version. The only difference between a tach and non-tach equipped truck is the circuit board on the back side of the instrument cluster. The signals are all still there whether you have a tach or not.
My '81 came without a tach, and I simply swapped in an instrument cluster that had one and it worked immediately.
  #71
Old 02-17-2014, 01:05 PM
To all: I have a harness off of a 79 F150 I6-300. The problem is, it has a large duraspark connection and a different Gray connection on the module side. I have a 4-pin, 3-pin and a 2-pin plug on my engine harness!!??
  #72
Old 02-17-2014, 01:31 PM
ctubutis's Avatar
Pictures, please?
  #73
Old 02-17-2014, 02:13 PM
  #74
Old 02-17-2014, 02:14 PM
  #75
Old 02-17-2014, 02:15 PM
The first pic, is of the engine wiring harness plugs. The second pic, is of the ignition module plug ends (module side).
HOWTO - DSII Conversion (swap from TFI or EECIII / EECIV to DSII) ctubutis '80-'86 HOWTO's 2 05-21-2015 09:18 AM
Electrical Plugs Photo's and Q's 1983F1503004x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-05-2011 02:06 PM
Got Truck: '78 F150 SWB! XxWINxX94 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-18-2011 07:58 PM
My recent Mod's, Bull Bar, Fog Lights, CB Radio, Back Up Camera, Reverse Lights brd7666 1999 to 2016 Super Duty 15 11-09-2010 08:33 PM
OT?: Detailing the Ex...pics inside ajorn Excursion - King of SUVs 22 03-02-2010 02:26 PM
Tags
1986, 460, conversion, duraspark, f150, flathead, ford, georgia, i6, ii, parts, picture, plugs, spark, upgrade, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
