Duraspark II Conversion - How To - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-07-2012, 10:05 AM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
The $30 eBay things don't have a real good reputation for longevity out here on FTE.
  #32
Old 11-27-2012, 07:32 PM
85BRONCOXLT 85BRONCOXLT is offline
85BRONCOXLT is starting off with a positive reputation.
i know this is an old thread but im just starting with my bronco!! can i use a carb off the truck i get the duraspark system out of? just to get me started till i upgrade the intake manifold? this seems very basic swap and ill be shopping thwe wrecking yards for parts as soon as christmas is over. also none of the pictures were there???
  #33
Old 11-27-2012, 09:52 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Yes, you can use the carb off the same truck you got the DSII distributor out of. Even better is one off a mid 70s truck, since it'll be pre-EGR / emissions oriented.
All the pictures were there for me. Something blocking them?
  #34
Old 11-28-2012, 12:59 AM
im at work maybe the system is blockin the photos... hopefully they work at home because that will help me out a lot. ill try to find the duraspark system and carb in a mid 70s truck then. might buy a new distributor tho just cuz of the rainy weather here in oregon. probably pick up a rebuild kit for the carb before it gets installed. time to get out the mud boots and go digging around at the wrecking yard.
  #35
Old 11-28-2012, 10:28 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Be aware that at some point, Ford changed the spacing of the two bolts which hold down the carburetor. The earlier models were a little closer to each other. With a round file, one can easily elongate the holes if needed.
During a Duraspark2 conversion, I replaced the feedback carburetor on my 1986 with a Carter YF from a 1970 F350. It took about 15 minutes to modify the mounting holes and it works great!
  #36
Old 02-16-2013, 01:27 AM
99f250XL-4.6 99f250XL-4.6 is offline
99f250XL-4.6 is starting off with a positive reputation.
1984 f150 300 6 feedback carb distib computer yank"
HELP,,,, getting rid of the current feedback carb & distrib & (computer)
which i know nothing about AND WHERE ???? putting an earlier carter and a duraspark distrib (all rebuilt)and an NEW msd box, what should be removed or taped off as far as the computer and wirering?? ???
  #37
Old 12-13-2013, 10:24 PM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
Holy Thread Revival..
Quick question I hope
When you removed the computer, wiring, etc
What did you do about the EVAP and SMOG pump? I 'think' the evap has a computer controlled solenoid so if the computer is gone..
I see you just got rid of (blocked off) the EGR
I'm getting ready to do the same thing but am trying to figure out what all is computer controlled and will need to be dealt with
Thanks!
  #38
Old 12-14-2013, 12:39 AM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is online now
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
I love the versatility of the DS2 dizzy. I run mine with an MSD box and a TFI coil. The msd can be used with or without the ford box. I run mine w/o it.
  #39
Old 12-14-2013, 01:13 AM
KsCop's Avatar
Still have the computer hooked up?
What about EGR, Smog pump and Evap?
  #40
Old 12-14-2013, 09:11 AM
bill06447 bill06447 is offline
bill06447 is gaining momentum as a positive member of FTE.
The EVAP system will work using only a couple vacuum ports, no solenoids needed (it's how it was done on older engines-they have been using it since the late 60s) You may need to scrounge a canister from an older car/truck. Here's a simplified diagram http://www.agcoauto.com/content/imag...hanced.jpg.jpg ~Bill
  #41
Old 12-28-2013, 10:30 PM
grsjr73 grsjr73 is offline
grsjr73 is starting off with a positive reputation.
Smile
I just finished doing this conversion on my 1986 F150 300 I6
and it was something i had been wanting to do for awhile.
I searched and read trying to get all the info to do it. Then I found your post and just let me say thank you for the detail and pics of how to get this done. It went very well and the truck is running great Thanks !!
  #42
Old 01-05-2014, 10:09 PM
woodbutcher05 woodbutcher05 is offline
woodbutcher05 is starting off with a positive reputation.
I am now on my second DS2 setup.The first was on my 1974 F100 with a 302.That setup came off of a Lincoln.The one that I am using now is on my 1984 F150 with a 300 6cyl.Cost for both systems was ZERO.Now have a total of appx 200K miles total on both systems with NO failures.A little hint to increase the reliability of the ignition boxes,is to run an extra GROUND wire from one of the mounting screws for the box to the firewall or some other suitable place.
Good luck.Have fun.Be safe.
Leo
  #43
Old 01-21-2014, 12:17 AM
Sean_Reno Sean_Reno is offline
Sean_Reno is starting off with a positive reputation.
85'F150: why can't I use my existing ignition harness and just swap out the distributor and box!?
  #44
Old 01-21-2014, 07:34 AM
Quote:
The existing harness isn't designed to plug into the DuraSpark II setup. There aren't the proper plugs or connections.
  #45
Old 01-21-2014, 08:40 PM
Quote:
Do I use the Blue DS II Module w/1 or 2 Plugs/whats the difference!?
What did you do to the X today? Snowseeker Excursion - King of SUVs 44866 Yesterday 10:14 PM
HOWTO - DSII Conversion (swap from TFI or EECIII / EECIV to DSII) ctubutis '80-'86 HOWTO's 2 05-21-2015 09:18 AM
The Red Wire Question 1983F1503004x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 03-15-2013 01:31 PM
OT?: Detailing the Ex...pics inside ajorn Excursion - King of SUVs 22 03-02-2010 02:26 PM
Engine Build Pictures (large file sizes) and Update 79F150EFI 1994.5 - 1997 7.3L Power Stroke Diesel 10 08-27-2007 07:33 PM
Tags
1986, 460, conversion, duraspark, f150, flathead, ford, georgia, i6, ii, parts, picture, plugs, spark, upgrade, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
