Duraspark II Conversion - How To - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 08-31-2014, 11:07 AM
1984Ford300six 1984Ford300six is offline
1984Ford300six is starting off with a positive reputation.
What is the correct float height? do i bend it higher or lower in the bowl?
  #152
Old 09-01-2014, 04:29 AM
Sean_Reno Sean_Reno is offline
Sean_Reno is starting off with a positive reputation.
Sorry, for the late response. The paperwork that came w/ my carb says 3/8 gap, 1 1/4" drop. Remember don't bend the arm/use the tab. Also, if you turn the carb upside down, small parts "WILL" fall out.
  #153
Old 12-27-2014, 10:56 AM
adperk94 adperk94 is offline
adperk94 is starting off with a positive reputation.
Duraspark II COnversion Help
I'm hoping to get some help from the DS II swap "experts" out there...
I decided to swap out the computerized TFI ignition and feedback carb on my 300 I6 in my 1985 Bronco. I found this thread before i even started and used it to gather the parts I needed. I went ahead and bought everything new with the exception if the wiring harness, it came out of a junkyard 1978 F-150 with what looked to be a 302 (definitely a small block) but the plugs that go to the main truck harness do not match up with mine nor do they fit any description that I found in this thread. Everything that I've read in this thread show the wiring harness to be a direct plug & play but I'm not that lucky i guess. I took some pictures of the problems I ran into.
These are the 3 connectors that I have coming out the firewall
These are the 3 connectors on the end of the harness form the junkyard truck
This is the junkyard harness plugged into the ignition box
This is a plug from the firewall harness plugged into the other connector on the box
These are the 2 left over firewall harness plugs that don't have a match
These are the 2 left over junkyard harness plugs that don't have a match
  #154
Old 12-27-2014, 11:02 AM
78' is too early for the harness. You need one from like an 82' w/the DSII Ignition.
  #155
Old 12-27-2014, 11:10 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Sean is probably right.
To add to that, you need to be matching up wire colors, ignoring the connectors.
IIRC the oval-shaped two-prong connector is for a dash-mounted tachometer.
If you've been researching a DS2 swap, then surely you know the red connects to the white and the white connects to the red.... in a certain location under the hood, I believe where the module connects to the truck harness but don't remember for certain...
  #156
Old 12-27-2014, 11:17 AM
I did the DSII Swap on my 85' w/4.9L. I looked at a lot of harnesses...the ones from the late 70's were different (gray firewall plug, etc) and some of the early 80, 81's were hit or miss...I kept finding CA Emissions Trucks. The later years 83, 84, 85 went to DSIII. I used one from an 82 (plug and play).
  #157
Old 12-27-2014, 11:19 AM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.
Do you have a stock tach?
What coil are you using?
You needed a 1980-84 harness off a 6 cyl to have a direct swap.
Jim
  #158
Old 12-27-2014, 12:00 PM
Where I am...Nevada...not all 80-84 trucks had the right harness...all 82's did though. And of course a V8 harness will work (just a bit longer/same plugs).
  #159
Old 12-27-2014, 12:40 PM
JimsRebel's Avatar
Quote:
I agree, 82-83 truck are the best choice, but still look at 80-84 trucks.
On a V8 truck you have to cut the black wire on the tach connector, between the DS2 IGN box and the plug, to get the tach to read correctly for a six cyl.
The older harness, pre 1980 will still work with some extra wiring work. It ends up being a mix of the old original harness with the DS2 harness.
Jim
  #160
Old 12-27-2014, 12:53 PM
You can always make your own too LOL
  #161
Old 12-27-2014, 12:57 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I did that. Wasn't bad at all. But I shade-treed it and used 1/4" quick disconnects.
  #162
Old 12-27-2014, 01:08 PM
I had about 2 dozen trucks to choose from, so it was easier "for me" just to grab one and I had mine swapped and running by the end of the weekend.
  #163
Old 12-27-2014, 01:11 PM
I do not have a stock tach, and the coil is just an aftermarket canister coil that uses the crescent shaped connector.
Would it be easily done to wire the 78 harness to work, or more worth my time to find a later harness? I'm in midwest Ohio I doubt I would run into too many CA trucks.
  #164
Old 12-27-2014, 01:39 PM
ruglyot's Avatar
ruglyot ruglyot is offline
ruglyot is starting off with a positive reputation.
I'm in the middle of this project myself (computer delete, Duraspark convert) and I'm going with the "make my own harness" route. The biggest thing I think is crucial is connector integrity, that is good, tight and accurate connections. I'm using Weatherpak connectors (because I have a bunch) - but a quality mating connection will insure your ignition circuit works, is easily repairable down the road and wont give you trouble-shooting gremlins as you continue with your project. My two cents. Russ
  #165
Old 12-27-2014, 01:49 PM
Gary Lewis's Avatar
How are you going to have an easily-repairable ignition using Weatherpaks when all the ignitions you'll buy have the Ford connectors?
HOWTO - DSII Conversion (swap from TFI or EECIII / EECIV to DSII) ctubutis '80-'86 HOWTO's 2 05-21-2015 09:18 AM
Electrical Plugs Photo's and Q's 1983F1503004x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-05-2011 02:06 PM
Got Truck: '78 F150 SWB! XxWINxX94 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-18-2011 07:58 PM
My recent Mod's, Bull Bar, Fog Lights, CB Radio, Back Up Camera, Reverse Lights brd7666 1999 to 2016 Super Duty 15 11-09-2010 08:33 PM
OT?: Detailing the Ex...pics inside ajorn Excursion - King of SUVs 22 03-02-2010 02:26 PM
Tags
1986, 460, conversion, duraspark, f150, flathead, ford, georgia, i6, ii, parts, picture, plugs, spark, upgrade, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
