I am buying a 2008 Ford E-350 Econoline Wagon Van with 64k on it. Does the V8 have any problems I should look for in particular??? How many miles can I expect out of a well maintained 5.4?? What is the average mileage do you get??
How many quarts does it take to change the oil???
Is the tranny reliable?? Does it need to be changed at certain intervals??
Does the rear dif fluid need to be changed at certain intervals???
Fuel mileage? No idea. My 2007 F-250 with a 5.4L gets between 8-18 depending on if/what I am towing or hauling, speed and weather. Your mileage may vary.
My 08 e250 w/4.6 and 4.10 gears loaded gets 13mpg. The powertrain is good, but I had to have all ball joints and one wheel bearing replaced at 43,000 miles.
The 2V Triton engines had one issue. They spit spark plugs. Usually, a spark plug being ejected from the head can be attributed to improper spark plug installation. (You only tighten them just a little beyond finger tight).
