I just got mine and it hasn't done much work YET. Ill get pictures when it does. Just wanted to see every ones trucks at work, not just at the mall parking lot LOL.
While some of these photos show some good amounts of weight....in others I have loaded more weight into the back of my lil Ford Ranger with upgraded springs...
Have 01 F250 with 2 pallets of brick that was OVERLOAD for 200k miles 5.4L with bad tran. It hold fine. Forgot to get picture. We guess it was around 4-5K lb.
95 F250 1 pallet of brick but PO didn't think how to build flatbed with steel near to rear tire so I only can hold 2,800 lb without rubbing steel.
00 F350 2wd diesel It hardly overload it never ever move inch low.
01 F250 V10 4wd that went to car crush due rot. leaf spring been replaced before.
So you're saying that in order to be considered "working" it has to be sittin' on the bump stops? Let's see some pics of your truck working.
Not much weight in this pic but right after you pull the trigger, it sure is alot like work. Only a five point but it'll taste just fine
