1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Show me pictures of those SUPER DUTY'S working.
Old 11-23-2015, 06:41 AM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
I haul a very similar dump trailer with similar loads (just not an excavator). I upgraded my hitch to that Titan hitch. Rated for 2000lb weight carrying tongue weight as most dump trailers don't use WD hitch. It's also rated at 18,000lbs. The matching ball mount is one huge piece of steel, not a hollowed tube like most ball mounts.
His excavator looks like it's centered over the axles to help with all that weight and tongue weight.
Can you just drive that excavator up or do you need to use the arm to help?
  #2912
Old 11-23-2015, 07:07 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
MDS- The early Super Duty trucks like my 99 through I believe 2002 including the Excursions up to 2002 have a hitch rated at 5k/10K. The 2002 + trucks received larger hardware upping it to 6k/12k. This is where my question stemmed from.
https://www.ford-trucks.com/forums/9...-hardware.html
  #2913
Old 11-23-2015, 07:44 AM
MDSuperDuty
For sure.
I think my factory 2-1/2" was 8000-15,000. I decided to up the 18,000lb Reese model because it wasn't all that expensive. Gives me some piece of mind that the hardware is up to the task. It's also hooked to the frame in other places than just the underside rail of the frame.
  #2914
Old 11-24-2015, 12:06 AM
KTZ's Avatar
KTZ
KTZ is offline
Originally Posted by Bently_Coop
@KTZ Looks good. What is your hitch rated at?
There was (currently its stripped off along with everything else behind the cab) Curt Hitch rated to 17K with a 2K toinge weight. I don't think I would attempt it with the stock hitch. I was taking up into the woods over some pretty rough logging roads, and it was pounding me pretty good.
The excavator climbs right up the ramps - it just fits!
Those are good prices on the 6.0 cooler. If the one I already bought does not cut the mustard I'll have to go for that one.
Also do you have a build thread with all the work being done?
I was thinking of doing a thread. Is there a specific place to post it, or should I just post it in the main fourm?
I'm not doing anything crazy, just replacing a lot of stuff with stock parts and adding some durability/longevity/towing themed mods. I don't want to get off topic here, but I'll post more details in a new thread.
  #2915
Old 11-24-2015, 01:30 AM
Bently_Coop
You can make a build thread here or in your Engine specific forum works too.
Also the OEM 6.0L cooler bolts into factory holes, it does require some barbed fittings to adapt though. Link below has some details.
https://drive.google.com/viewerng/vi...MGM2YzhiYTliZQ
  #2916
Old 11-24-2015, 06:52 AM
MDSuperDuty
It looks like your dump trailer is very similar to mine deck height wise, just different manufacturers. The ramps make for a rather steep climb up and I wasn't sure how larger equipment would handle it. I don't use one but I always figured a skidsteer would need to be backed on, throwing off tongue weight. Also that an excavator would need to use the arm to help it from tipping.
I've seen some, maybe yours has them, that have two jacks on each side of the rear so when loading your truck bed isn't sky high when the equipment is on the ramp and rear of the trailer. Do you raise the dump bed when loading the excavator?
  #2917
Old 11-25-2015, 04:01 PM
KTZ's Avatar
KTZ
KTZ is offline
My ramps are about 6 feet long, which gives a reasonable incline to run either the bobcat or the backhoe in either forwards or backwards. When I load them i just have to have the trailer hooked up to the truck. I truck some blocks on the trailer wheels to save my transmission.
  #2918
Old 12-14-2015, 08:14 AM
Grizzly4x4's Avatar
Grizzly4x4
Grizzly4x4 is offline
Originally Posted by FordMuddin'
2001 f250 5.4 5 speed... All the way to 335,000 miles before she was retired... Havin trouble passing emmissions. No better truck to work off of tho i miss it. And then theres the new truck soon to be worked, 2004 f250 king ranch v10 60k miles, already put helwig lp 25 springs in it, sct tuner and hedman headers.
Man, I love the setup you had. Did you build the bed yourself?
  #2919
Old 12-14-2015, 08:20 AM
Grizzly4x4's Avatar
Grizzly4x4
Here's mine from last weekend.
<a href="http://imgur.com/qtAbOmS"><img src="https://i.imgur.com/qtAbOmSh.jpg" title="source: imgur.com" /></a>
  #2920
Old 12-14-2015, 09:32 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
truck, motorcycle and trailer . 17,000 pounds Total rolling.
  #2921
Old 12-14-2015, 01:59 PM
AndyKY's Avatar
AndyKY
AndyKY is offline
Here's mine going fishing:
  #2922
Old 12-16-2015, 06:21 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
anyone know the name/color code of this color?
  #2923
Old 12-16-2015, 06:46 PM
1badcj8's Avatar
1badcj8
1badcj8 is offline
Doing some light work...
  #2924
Old 12-16-2015, 06:56 PM
LaxPlaya21's Avatar
LaxPlaya21
LaxPlaya21 is offline
Here are the BFGs
  #2925
Old 12-17-2015, 06:26 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
How did you already get that 17 inspection sticker on there...or did I sleep through the last 2 weeks of 2015
Sarge
Quick Reply: Show me pictures of those SUPER DUTY'S working.
