Show me pictures of those SUPER DUTY'S working.
#3260
Looks like you have a Reese hitch. If you are looking for sway control, you should look at adding the dual cam straight line arms. You're half way there already since you have the right spring bars for them.
Thats what I'm using and I cant believe how well it works. I'm towing 31ft with a 119" wheelbase and no sway no matter the crosswind or passing trucks.
#3263
I'm sure the friction bars work, but I truly believe the straight line setup is much better. It is their flagship hitch.
https://www.etrailer.com/Weight-Dist...e/RP26002.html
In a side wind, the bars have enough straight line forces to turn the truck straight with the trailer. Both vehicles move as a unit in a straight line no matter what. Going around corners, you can feel the hitch forcing the trailer straight with the truck.
I'm very happy with the performance of mine. Especially with my combination.
#3264
#3265
Just flop the bars loose when backing up, or if it's really a tight turn remove them it takes literally under a minute. You don't need an weight distribution hitch when you're off the road parking..... I don't know if this is even required on newer hitches.
#3266
#3267
#3268
i bet the tolls love that thing too... nice looking truck and camer there.. same your selling both...
